Author Topic: VLX File unable to load  (Read 2530 times)
diago
« on: April 29, 2019, 01:13:21 PM »
I have a VLX file (attached file) to load on AutoCAD but the issue is that every time I  try to load the file it just says: "Unable to load ....VLX file".
Please I would like to solve this problem. The password for the VLX file is "romatelo" (without quote marks).
Thanks in advance.
EDIT (John): Removed attached VLX. I apologize, but until we determine if it is safe for others to download/run I cannot allow it to be posted. Please post the source code instead.
« Last Edit: April 29, 2019, 02:59:53 PM by John Kaul (Se7en) »
Re: VLX File unable to load
« Reply #1 on: April 29, 2019, 02:56:20 PM »
Do you have the source code for the VLX file? Sorry, but you should not post "compiled" files (most people here will not download them).
diago
« Reply #2 on: April 29, 2019, 03:21:28 PM »
Sry about that. It has been a while since I made my last post. What do you mean with "source code"?
« Reply #3 on: April 29, 2019, 03:26:27 PM »
No problem.
The source is the file you used to create the VLX from. The one with all the "(defun foo () " type code in it.
dgorsman
« Reply #4 on: April 29, 2019, 07:44:47 PM »
Put another way: did you create this yourself, or did you download it from somewhere?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
diago
« Reply #5 on: May 01, 2019, 09:40:13 AM »
I download it from youtube it was a video (spanish language) to make location plans and a grid UTM coordinates and so on in AutoCAD.
I really would like to create that kind of Autolisp routine. I am afraid it wouldn't help so much the way I put it here :(
But some one could guide me to develop that kind of routine lisp? I really appreciate it so much.
Thanks in advance!
ChrisCarlson
« Reply #6 on: May 01, 2019, 12:11:02 PM »
Unfortunately without the original code used to make the VLX file you'll need to contact the original author for more guidance.
diago
« Reply #7 on: May 01, 2019, 09:43:21 PM »
Thank you all anyway.
