Author Topic: Modemacro  (Read 5411 times)
GDF
Modemacro
« on: April 27, 2019, 10:00:31 AM »
Has anyone been able to display text on to the status bar, using modemacro?
Does BricsCAD have this function?
Re: Modemacro
« Reply #1 on: April 27, 2019, 10:07:09 PM »
works at the command line
Retired
roy_043
  • BricsCAD 18
Re: Modemacro
« Reply #2 on: April 28, 2019, 03:30:43 AM »
Seems to work OK. But I do notice that the text does not update when hovering over certain GUI elements. For example while running the code below and hitting the ESNAP button in the Status Bar.
  1. (setvar "MODEMACRO"
  2.   (strcat
  3.     "$(if,$(=,$(getvar,OSMODE),0),** OSNAPS OFF ** ,)"
  4.     "$(if,$(=,$(and,$(getvar,OSMODE),    1),0),,END )"
  5.     "$(if,$(=,$(and,$(getvar,OSMODE),    2),0),,MID )"
  6.     "$(if,$(=,$(and,$(getvar,OSMODE),    4),0),,CEN )"
  7.     "$(if,$(=,$(and,$(getvar,OSMODE),    8),0),,NOD )"
  8.     "$(if,$(=,$(and,$(getvar,OSMODE),   16),0),,QUA )"
  9.     "$(if,$(=,$(and,$(getvar,OSMODE),   32),0),,INT )"
  10.     "$(if,$(=,$(and,$(getvar,OSMODE),   64),0),,INS )"
  11.     "$(if,$(=,$(and,$(getvar,OSMODE),  128),0),,PER )"
  12.     "$(if,$(=,$(and,$(getvar,OSMODE),  256),0),,TAN )"
  13.     "$(if,$(=,$(and,$(getvar,OSMODE),  512),0),,NEA )"
  14.     "$(if,$(=,$(and,$(getvar,OSMODE), 1024),0),,GCE )"
  15.     "$(if,$(=,$(and,$(getvar,OSMODE), 2048),0),,APP )"
  16.     "$(if,$(=,$(and,$(getvar,OSMODE), 4096),0),,EXT )"
  17.     "$(if,$(=,$(and,$(getvar,OSMODE), 8192),0),,PAR )"
  18.     "$(if,$(=,$(and,$(getvar,OSMODE),16384),0),,** OSNAPS OFF ** )"
  19.   )
  20. )
« Last Edit: April 28, 2019, 03:37:30 AM by roy_043 »
GDF
Re: Modemacro
« Reply #3 on: April 28, 2019, 07:28:33 AM »
Thanks Daniel and Roy
« Last Edit: April 28, 2019, 08:00:35 AM by GDF »
GDF
Re: Modemacro
« Reply #4 on: April 30, 2019, 02:07:37 PM »
Part of my problem was that I had the status bar toggled off.
 :idiot2:
ScottMC
Re: Modemacro
« Reply #5 on: December 19, 2021, 06:00:03 PM »
Just wondering if others using this macro have seen a similar difficulty. when adding more to this, my A2K crashes [0x0004] still it's helpful. One change I use is adding the "!" to inverse and make it shorter exp:
[ "$(if,$(!=,$(and,$(getvar,OSMODE),    1),0),,END )" ]
