...well I solved the duplicated problem.
How did you solve the issue ?
... but now I build the DLL file but SS-renumber-all and SS-RENUMBER-ALL-BASES-OF-FIRST does not work.
So,
Does it compile without error ?
Does it NetLoad into AutoCAD without issue ?
Does each command appear to run without fault ?
Have you tried stepping through the code in the debugger to check the code flow ?
0 How did you solve the issue?
0 AUTODESK WIZARD automatically creates 2 ".CS", I just left one ".CS", deleted all and pasted all the code.
1 Does it compile without error?
1 YES
2 Does it NetLoad into AutoCAD without issue?
2 YES
3 Does each command appear to run without fault?
3 Do nothing both commands after loading with NETLOAD
3 But load both commands without problems.
4 Have you tried stepping through the code in the debugger to check the code flow?
4 yes, do nothing when debugging
4 Does not load both commands
Here 2 versions of the same developer, maybe there is the issue:
http://www.theswamp.org/index.php?topic=45672.msg508180#msg508180
...and here another version (a 3rd ) of the same code with same commands:
https://sites.google.com/site/acadhowtodo/net/sheet-set/update-sheets-numbers
...So, What can I do now?
