Author Topic: How to update a 2014 C#.NET to 2020 version?  (Read 9047 times)
jtm2020hyo
Re: How to update a 2014 C#.NET to 2020 version?
« Reply #15 on: April 21, 2019, 02:52:34 PM »
my noob .dll file works.
just that does not work as I need.
here an example:
example using command "SS-renumber-all-bases-of-first"
example using command "SS-renumber-all"
Thanks everyone
« Last Edit: April 23, 2019, 01:05:08 PM by jtm2018hyo »
jtm2020hyo
« Reply #16 on: April 21, 2019, 03:42:47 PM »
 * SheetSetTools. © Andrey Bushman, 2013
 * AutoCAD 2014 x64 Enu
 * COMMANDS:
 * SS-RENUMBER-ALL - Update the numeration for all sheets in the all opened sheet sets:
 * numbering of each subgroup shall begin with 1.
 * SS-RENUMBER-ALL-BASES-OF-FIRST - Update the numeration: to continue numbering on the
 * basis of the first element in the each subset (in the all opened sheet sets).
 * AutoCAD references:
 * AcCoreMgd.dll
 * AcDbMgd.dll
 * AcMgd.dll
 * Interop.ACSMCOMPONENTS22Lib.dll
using System;
using cad = Autodesk.AutoCAD.ApplicationServices.Application;
using App = Autodesk.AutoCAD.ApplicationServices;
using Db = Autodesk.AutoCAD.DatabaseServices;
using Ed = Autodesk.AutoCAD.EditorInput;
using Rtm = Autodesk.AutoCAD.Runtime;
using Comp = ACSMCOMPONENTS22Lib;
[assembly: Rtm.ExtensionApplication(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))]
[assembly: Rtm.CommandClass(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))]
namespace Bushman.AutoCAD.SheetSetTools
    public class SheetSetCommands : Rtm.IExtensionApplication
        const String ns = "bush"; // namespace
        /// <summary>
        /// Update the numeration for all sheets in the all opened sheet sets: numbering of
        /// each subgroup shall begin with 1.
        /// </summary>
        [Rtm.CommandMethod(ns, "ss-renumber-all", Rtm.CommandFlags.Modal)]
        public void Renumber_All()
            Renumber();
        /// <summary>
        /// Update the numeration: to continue numbering on the basis of the first element
        /// in the each subset (in the all opened sheet sets).
        /// </summary>
        [Rtm.CommandMethod(ns, "ss-renumber-all-bases-of-first", Rtm.CommandFlags.Modal)]
        public void Renumber_all_bases_of_first()
            Renumber(true);
        /// <summary>
        /// To update numbering of all sheets in the all opened sheet sets.
        /// </summary>
        /// <param name="continue_numbering">True - to continue numbering on the basis
        /// of the first element in the each subset (in the all opened sheet sets);
        /// False - Numbering of each subgroup shall begin with 1 (in the all opened
        /// sheet sets).</param>
        void Renumber(Boolean continue_numbering = false)
            App.Document doc = cad.DocumentManager.MdiActiveDocument;
            Db.Database db = doc.Database;
            Ed.Editor ed = doc.Editor;
            Comp.AcSmSheetSetMgr mng = new Comp.AcSmSheetSetMgr();
            Comp.IAcSmEnumDatabase enumerator = mng.GetDatabaseEnumerator();
            enumerator.Reset();
            Comp.AcSmDatabase smDb = null;
            while ((smDb = enumerator.Next()) != null)
                smDb.LockDb(db);
                String fname = smDb.GetFileName();
                Comp.AcSmSheetSet sheetset = smDb.GetSheetSet();
                String name = sheetset.GetName();
                String descr = sheetset.GetDesc();
                ed.WriteMessage("\nSheet Set name: {0}\n", name);
                Int32 ren_count = 0; // count of renamed sheets.
                Comp.IAcSmEnumComponent encomp = sheetset.GetSheetEnumerator();
                encomp.Reset();
                Comp.IAcSmComponent component = null;
                while ((component = encomp.Next()) != null)
                    ProcessElement(ed, component, ref ren_count, continue_numbering);
                encomp.Reset();
                smDb.UnlockDb(db, true);
                ed.WriteMessage("Renumbered sheets count: {0}\n", ren_count);
            enumerator.Reset();
        /// <summary>
        ///  Recursive processing of the elements: change the sheet's number.
        /// </summary>
        /// <param name="ed">An Editor for the output.</param>
        /// <param name="component">Component of Sheet Set.</param>
        /// <param name="ren_count">The count of renumbered sheets in the sheet set.</param>
        void ProcessElement(Ed.Editor ed, Comp.IAcSmComponent component,
            ref Int32 ren_count, Boolean continue_numbering)
            component.GetDirectlyOwnedObjects(out Array array);
            if (array != null)
                Int32 sheet_number = 1;
                Boolean basis_of_first = continue_numbering;
                foreach (var item in array)
                    if (item is Comp.IAcSmSubset)
                        ProcessElement(ed, (Comp.IAcSmSubset)item, ref ren_count, continue_numbering);
                    else if (item is Comp.IAcSmSheet sheet)
                        String cur_str_value = sheet.GetNumber();
                        Boolean is_int32 = Int32.TryParse(cur_str_value, out int int_value);
                        if (!is_int32 || (!basis_of_first && int_value != sheet_number))
                            sheet.SetNumber(sheet_number.ToString());
                            ++ren_count;
                        else if (basis_of_first)
                            sheet_number = int_value;
                        ++sheet_number;
                        basis_of_first = false;
                    else if (item is Comp.IAcSmPersist persist)
                    else
                        ed.WriteMessage("Unknown object: {0}", item.GetType().ToString());
        #region IExtensionApplication Members
        public void Initialize()
            ed.WriteMessage("\nSheetSetTools. © Andrey Bushman, 2013\n\n");
        public void Terminate()
            // Empty body.
        #endregion
