Author Topic: New Insertion command in 2020  (Read 3620 times)
Andrea
« on: April 16, 2019, 08:38:52 AM »
Hi all,..
is Anyone experimenting problem with new insertion command in AutoCAD 2020 ?
when inserting blocks,...this new palette takes 4 sec to insert blocks each time we use it...even if the block selected is already in the drawing without any redefine mode. (see pic)
Keep smile...
rkmcswain
Re: New Insertion command in 2020
« Reply #1 on: April 16, 2019, 10:40:19 AM »
It works OK here.
If you use the command line version (-insert) does it still have the delay for you?
« Last Edit: April 16, 2019, 10:47:16 AM by rkmcswain »
« Reply #2 on: April 16, 2019, 11:23:22 AM »
Works fine here too ... have you tested more than one drawing?
« Reply #3 on: April 16, 2019, 12:07:06 PM »
Do you have many active reactors?
Andrea
« Reply #4 on: April 16, 2019, 12:27:00 PM »
new PC,  new installation,...no tools loaded,. Cad vanilla.
hhmm....:|
Thank you for your feedback,..If I found something i'll let you know.
have a good day.
Keep smile...
cmwade77
« Reply #5 on: April 16, 2019, 12:50:30 PM »
Not really, for most block insertion we just use classicinsert or tool palettes.
The only time we tend to use this new interface is when we are inserting multiple blocks from another drawing, this interface tends to work well for that, but normal block insertion, it is much more time consuming.
« Reply #6 on: April 16, 2019, 02:39:06 PM »
why not use design center?  unless they killed that off for this version?
cmwade77
« Reply #7 on: April 16, 2019, 05:37:27 PM »
Simply put, it is too complex for our needs. Yes, power users can use it fairly well, but the average user, not so much.
