Author Topic: Editor.Command() in a Viewport inside a paperspace layout  (Read 2818 times)
CrockettScience
  • Mosquito
« on: April 15, 2019, 05:57:26 PM »
Our goal is to basically do the equivalent of clicking into a viewport and executing Zoom => Extents to capture everything that's in model space, but in a C# command. The problem is that just executing editor.command() executes the command in for the layout, not the viewport. Is there a way to emulate "clicking" into a view first before executing?
Re: Editor.Command() in a Viewport inside a paperspace layout
« Reply #1 on: April 15, 2019, 06:30:15 PM »
In LISP the equivalent would be:
- set the sysvar tilemode to 0 (if not already)
- set the document's mspace property to true (if not already)
- set the sysvar cvport to the target viewport's id (if not already)
No command calls required. Should be easy to replicate in C#. Cheers.
Bryco
« Reply #2 on: April 15, 2019, 07:51:19 PM »
acadApp.SetSystemVariable("Tilemode", 0);   0 and 1 toggles
ed.SwitchToModelSpace  Makes a vp active
 ed.SwitchToPaperSpace();   makes paperspace active
CrockettScience
  • Mosquito
« Reply #3 on: April 16, 2019, 02:18:15 PM »
So in the event you have multiple Vp's, how do you know which one will become active, and how can you specify that in .NET?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #4 on: April 16, 2019, 03:50:32 PM »
See if this helps
https://help.autodesk.com/view/OARX/2019/ENU/?guid=GUID-5FA86EF3-DEFD-4256-BB1C-56DAC32BD868
Code - C#: [Select]
  1.
  2.             acLayoutMgr.CurrentLayout = acLayout.LayoutName;
  3.
Called Kerry in my other life
I live at UTC + 13.00
Bryco
« Reply #5 on: April 16, 2019, 06:47:34 PM »
Here's a little code. The first viewport is always the paperspace viewport.
You could cycle through the viewports by size or scale etc to choose a particular one
LayoutManager lm = LayoutManager.Current;
                Layout layout = tr.GetObject(lm.GetLayoutId(lm.CurrentLayout), OpenMode.ForRead) as Layout;
                ObjectIdCollection vpIds = layout.GetViewports();
                if (vpIds.Count < 2)
                    MessageBox.Show("There are no viewports in this layout, exiting:");
                    return;
                if (db.PaperSpaceVportId == ed.CurrentViewportObjectId)// in paperspace viewport
                    if (vpIds.Count == 2)
                        vp = tr.GetObject(vpIds[1], OpenMode.ForWrite) as Viewport;
                        vp.Locked = false;
                        ed.SwitchToModelSpace();
                    else
CrockettScience
  • Mosquito
« Reply #6 on: April 17, 2019, 02:52:58 PM »
I see, now I get it. Thanks.
