I have a Lisp that creates two lists throug user-input. These lists are measurements of two different parts.
The lists can change in length. For example (top one in screenshot):
A (2 1 2) -> white-rectangles with "100+" in it
B (3 2) -> red dashed with value)
What I need is a list with points to put in 2 different blocks. (see screenshot, block A and block B)
The start and end-block I got covered.
List A only contains values of 1or 2
List B contains values of 1, 2, 3or 4
It should work in every combination where the total of the sum of the values in the lists are equal. (two more examples in screenshot)
I have been breaking my mind for hours and I cannot figure it out...
Kind regards,
Jeroen Berkers
