Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Arc to torus
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Arc to torus (Read 2663 times)
Jeremy Dunn
Newt
Arc to torus
on:
April 14, 2019, 01:08:22 PM »
I have the ename of an arc that is arbitrarily oriented in 3D, I wish to replace it with a section of a torus of tube radius r that has the same center and radius using LISP. What is the best way to go about doing this?
Logged
kpblc
Bull Frog
Re: Arc to torus
Reply #1 on:
April 14, 2019, 01:12:36 PM »
I think you have to create circle at the start point of arc (with current normal of circle), and then extrude by path your circle.
Logged
Sorry for my English.
Seagull
London, England
WWW
Re: Arc to torus
Reply #2 on:
April 14, 2019, 05:36:34 PM »
Consider the following function, compatible with both arcs & circles:
Code - Auto/Visual Lisp:
[Select]
;; Arc -> Torus - Lee Mac
;; ent - Arc or Circle entity
;; trd - Torus tube radius
defun
LM:arc
torus
ent trd
an1 an2 cen cir enx ocs pt1 rad reg rtn spc tcs var
setq
enx
entget
ent
rad
cdr
assoc
040 enx
if
and
trd rad
progn
if
"ARC"
cdr
assoc
000 enx
setq
an1
cdr
assoc
050 enx
an2
rem
pi pi
cdr
assoc
051 enx
an1
pi pi
setq
an1
0.0
an2
pi pi
setq
ocs
cdr
assoc
210
enx
cen
cdr
assoc
010 enx
pt1
trans
polar
cen an1 rad
ocs
0
tcs
v
v ocs
mapcar
pt1
trans
cen ocs
0
spc
vlax
ename
vla-object
cdr
assoc
330
enx
cir
entmakex
list
000 .
"CIRCLE"
cons
010
trans
pt1
0
tcs
cons
040 trd
cons
210
tcs
not
vl-catch-all-error-p
setq
var
vl
catch
all
apply
vla-addregion
list
spc
vlax
make
variant
vlax-safearray-fill
vlax
make
safearray
vlax-vbobject
0
0
list
vlax
ename
vla-object
cir
not
setq
rtn
vl
catch
all
apply
vla-addrevolvedsolid
list
spc
car
setq
reg
vlax
safearray
list
vlax
variant-value
var
vlax-3D-point
trans
cen ocs
0
vlax-3D-point
ocs
an2
entdel
ent
setq
rtn
nil
foreach
obj reg
if
and
vla-object
type
obj
vlax-write-enabled-p
obj
vla-delete
obj
if
and
'ename
type
cir
not
vlax-erased-p
cir
entdel
cir
rtn
;; Vector Cross Product - Lee Mac
;; Args: u,v - vectors in R^3
defun
v
v
u v
list
cadr
u
caddr
v
cadr
v
caddr
u
car
v
caddr
u
car
u
caddr
v
car
u
cadr
v
car
v
cadr
u
Here's a program to test:
[Select]
defun
c:test
ent rad
if
and
setq
ent
car
entsel
\n
Select arc or circle: "
wcmatch
cdr
assoc
0
entget
ent
"ARC,CIRCLE"
progn
initget
6
setq
rad
getdist
\n
Specify torus tube radius: "
LM:arc
torus ent rad
princ
vl-load-com
princ
Logged
Lee Mac Programming
Twitter
Exchange App Store
Jeremy Dunn
Newt
Re: Arc to torus
Reply #3 on:
April 16, 2019, 07:33:48 PM »
Lee to the rescue!
I will study this one closely, I was having trouble figuring what the tangent vector at the start angle was.
Logged
Seagull
London, England
WWW
Re: Arc to torus
Reply #4 on:
April 17, 2019, 02:27:45 PM »
You're most welcome Jeremy - feel free to ask questions if you are unsure of anything.
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Arc to torus
