Author Topic: PRINT a TXT file, from VISUAL LISP  (Read 5039 times)
domenicomaria
« on: April 14, 2019, 05:06:38 AM »
I need to
PRINT a TXT file, from VISUAL LISP . . .
But
(DOS_SPOOL "c:\\LISP\\BLA-BLA-BLA.txt" (DOS_GETPRN) )
does not work !
my printer
says :
"Receiving data"
but never prints anything . . .
roy_043
  • BricsCAD 18
Re: PRINT a TXT file, from VISUAL LISP
« Reply #1 on: April 14, 2019, 07:53:59 AM »
Please stop posting the same problem again and again and again.
domenicomaria
« Reply #2 on: April 14, 2019, 11:28:03 AM »
Sorry !
I had a problem with your site !
When I try to send a post
it takes at least 10 minutes.
So I think that something is going wrong !
And later
i try again !
I apologize.
Please remove every thing
and leave only one instance !
sorry again !
ciao
BIGAL
  • 40 + years of using Autocad
« Last Edit: April 14, 2019, 09:48:38 PM by BIGAL »
domenicomaria
« Reply #4 on: April 16, 2019, 03:42:09 AM »
I tried :
(STARTAPP "print" path-filename-txt)
(DOS_SPOOL path-filename-txt (DOS_GETPRN) )
(STARTAPP "print /d:\"\\\\Dbroad\\Brother MFC-6490CW Printer\"" path-filename-txt)
they don't work
and however I don't understand
the syntax of the third row
I need a simple and working solution
ciao
roy_043
  • BricsCAD 18
« Reply #5 on: April 16, 2019, 04:39:38 AM »
Modern printers may not be able to handle a text file.
Try using notepad.exe. Look into its command line parameters.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #6 on: April 16, 2019, 04:40:04 AM »
I tried :
they don't work
ciao
I imagine it's not working because that is/was the address of Doug Broads printer, not yours.
Called Kerry in my other life
I live at UTC + 13.00
roy_043
  • BricsCAD 18
« Reply #7 on: April 16, 2019, 07:01:26 AM »
Try:
(startapp "notepad.exe /p \"X:\\Your path\\File.txt\"")
domenicomaria
« Reply #8 on: April 16, 2019, 09:59:20 AM »
"Sometimes the question is more important than the answer."
Yes. You are right !
"I imagine it's not working because that is/was
the address of Doug Broads printer, not yours."
What have I to do
to know my printer address
-> via Visual Lisp <- ?
or the printer address of a generic user ?
roy_043
  • BricsCAD 18
« Reply #10 on: April 16, 2019, 02:50:39 PM »
I did some work on this subject--in Cpp--at one point and it's a more difficult situation then one would expect. -i.e. if I remember properly, you can COPY a file to the COM/LPT port (COPY /B filename LPT1:) but the output depends file type you have (TXT, PS, PDF, etc.). In the end it is a big mess.
The knowing which COM/LPT port to send the information to is another big nasty problem. For my Cpp project I choose to use Redmon. Ultimately, I created redirected printer port(s) -i.e. connected a windows print driver to a redirected printer port and then used "redpr" (a better `copy to printer port method') to print my files. ...in the end, it is a bit of a mess and in the end, you'd probably be better off (save yourself a bunch of time) installing Redmon on everyone's machine (this can be automated).
ChrisCarlson
« Reply #11 on: April 16, 2019, 03:28:17 PM »
This thread has me intrigued, what would be the advantage or printing to a TXT file?
kdub_nz
  • SuperMod
« Reply #12 on: April 16, 2019, 03:54:06 PM »
,INI file
.XML file
.CSV file
General data file
etc, etc
domenicomaria
« Reply #13 on: April 16, 2019, 03:58:31 PM »
"what would be the advantage or printing to a TXT file?"
I wrote my
(internal to Autocad)
NOTEPAD !
Everything works well.
But not PRINT !
dgorsman
« Reply #14 on: April 16, 2019, 05:51:27 PM »
You might be misreading this; it's about printing a TXT file to hard copy, not printing to a TXT file.
FYI, the MSXML DOM has a 'save' method to put the contents of an XML DOMDocument to file, so there's no need to use "print" like that.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
