Author Topic: AutoCAD 2020 .NET wizard and ObjectARX wizard  (Read 8809 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Called Kerry in my other life
I live at UTC + 13.00
It's Alive!
  • Retired
  • AKA Daniel
Re: AutoCAD 2020 .NET wizard and ObjectARX wizard
« Reply #1 on: April 14, 2019, 09:12:15 AM »
Awesome! Thanks!
cnicho
« Reply #2 on: June 24, 2019, 03:33:00 PM »
Hi
Do you know if this should work with VS 2017 Community?
When I try to create a new ARX/DBX project it just redisplays the dialog without doing anything.
kdub_nz
  • SuperMod
« Reply #3 on: June 25, 2019, 01:48:51 AM »
I don't use ARX, so you'll need to wait for input ... or ask at the AutoDesk forums.
The .NET is meant for VS2017. From memory the Wizard loaded and ran.
I use VS2019 and build my own templates though so I'm not the one to ask about everyday use.
.... Just ran up 2017 and the wizard seems to load correctly.
Regards,
cnicho
« Reply #4 on: June 25, 2019, 02:57:09 AM »
Thanks for the reply.
Are you using the community editions?
kdub_nz
  • SuperMod
« Reply #5 on: June 25, 2019, 05:11:52 AM »
Yes
cnicho
« Reply #6 on: June 25, 2019, 06:43:01 AM »
I should have installed the wizards with admin rights.
« Last Edit: June 25, 2019, 08:16:32 AM by cnicho »
kdub_nz
  • SuperMod
« Reply #7 on: June 26, 2019, 07:01:30 PM »
Good.
Thanks for coming back to mention that.
sidewayz
« Reply #8 on: January 26, 2020, 07:28:47 PM »
I have tried all versions of the wizards, installing as admin, on 2017 and 2019 and cannot seem to get them to appear in Visual Studio..
Is there any new information pertaining to these issues?
Thank you.
