CAD Forums > CAD General
does anyone use a plasma cutter to cut letters?
andrew..:
Company has a plasma cutter and want to cut words out of the metal.
right now they make the words using line work... very time consuming.
i am looking to see if there is a font or a better/faster way to burn words out of sheet metal.
any info or tips is appreciated
ronjonp:
Use this: http://www.theswamp.org/index.php?topic=31435.msg589624#msg589624
andrew..:
thanks for the reply. I wasnt able to get this to load.
ronjonp:
What version of AutoCAD are you on?
Bryco:
If it does not need to be pretty use simplex.shx (One of the ugliest fonts but it is single stroke) then use the command tx to explode text (text not mtext)
Navigation
[0] Message Index
[#] Next page
Go to full version
