Author Topic: Draw line after choosing a color  (Read 1569 times)
jlogan02
« on: March 27, 2019, 06:17:32 PM »
It'll draw the line but not set the color. The numbers indicate AutoCAD color numbers.
Sooo...choose the color and draw the line.
  1. (defun c:Hline (/ hcol)
  2.  (initget 1 "1 56 136 191")
  3.   (setq hcol (getkword "\nEnter COLOR [1/56/136/191]: "))
  4.    (cond
  5.      ((eq hcol "1") 1)
  6.      ((eq hcol "56") 56)
  7.      ((eq hcol "136") 136)
  8.      ((eq hcol "191") 191)
  9.      (T hcol)
  10.       )
  11.    (command "_Line" pause hcol)
  12.    (princ)
  13.  )
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Re: Draw line after choosing a color
« Reply #1 on: March 27, 2019, 06:52:59 PM »
Try the code below. You cannot just put the color into the line command and expect it to know what to do with it.
  1. (defun c:hline (/ hcol p1 p2)
  2.   ;; RJP » 2019-03-27
  3.   (initget 1 "1 56 136 191")
  4.   (if (setq hcol (getkword "\nEnter COLOR [1/56/136/191]: "))
  5.     (while (and (or p1 (setq p1 (getpoint "\nSpecify start point: ")))
  6.                 (setq p2 (getpoint p1 "\nSpecify next point: "))
  7.            )
  8.       (entmakex (list '(0 . "line") (cons 10 p1) (cons 11 p2) (cons 62 (atoi hcol))))
  9.       (setq p1 p2)
  10.     )
  11.   )
  12.   (princ)
  13. )
Line command:
Command: LINE
Specify first point:
Specify next point or [Undo]:
Specify next point or [Close/Undo]:
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: March 27, 2019, 08:50:37 PM »
You can use -color prior to line call then dont need to entmake.
(defun test (  / oldcol hcol p1 p2)
  (setq oldcol (getvar 'cecolor))
  (setvar 'cecolor" (atoi hcol))
      (command "line" p1 p2 "")
      (setq p1 p2)
  (setvar 'cecolor oldcol)
(test)
My version of initget look at image uses a library multi button lsp
jlogan02
« Reply #3 on: March 29, 2019, 11:42:05 AM »
Thanks guys, both are right in line with what I was thinking. I need to "remember" last input and do some layer creation stuff, but this gets me closer.
Thanks again.
J. Logan
ACAD 2018
