how can I run this c# 2013 routine in CIVIL 3D or AUTOCAD VANILLA?
* © Andrey Bushman, 2013
* AutoCAD 2014 x64 Enu
* AutoCAD references:
* AcCoreMgd.dll
* AcDbMgd.dll
* AcMgd.dll
* Interop.ACSMCOMPONENTS19Lib.dll
using System;
using System.Linq;
using System.Text;
using cad = Autodesk.AutoCAD.ApplicationServices.Application;
using App = Autodesk.AutoCAD.ApplicationServices;
using Db = Autodesk.AutoCAD.DatabaseServices;
using Ed = Autodesk.AutoCAD.EditorInput;
using Rtm = Autodesk.AutoCAD.Runtime;
using Comp = ACSMCOMPONENTS19Lib;
[assembly: Rtm.CommandClass(typeof(Bushman.AutoCAD.SheetSetEditor.Commands))]
namespace Bushman.AutoCAD.SheetSetEditor {
public class Commands {
const String ns = "bush"; // namespace
[Rtm.CommandMethod(ns, "test", Rtm.CommandFlags.Modal)]
public void Renumber() {
App.Document doc = cad.DocumentManager.MdiActiveDocument;
Db.Database db = doc.Database;
Ed.Editor ed = doc.Editor;
Comp.AcSmSheetSetMgr mng = new Comp.AcSmSheetSetMgr();
Comp.IAcSmEnumDatabase enumerator = mng.GetDatabaseEnumerator();
Comp.AcSmDatabase smDb = null;
while ((smDb = enumerator.Next()) != null) {
String fname = smDb.GetFileName();
Comp.AcSmSheetSet sheetset = smDb.GetSheetSet();
String name = sheetset.GetName();
String descr = sheetset.GetDesc();
ed.WriteMessage("\nSheet Set: {0}\n", name);
Comp.IAcSmEnumComponent encomp = sheetset.GetSheetEnumerator();
Comp.IAcSmComponent component = null;
while ((component = encomp.Next()) != null) {
ProcessElement(ed, component, 0);
encomp.Reset();
enumerator.Reset();
// Recursive processing of the elements
void ProcessElement(Ed.Editor ed, Comp.IAcSmComponent component, Int32 level) {
ed.WriteMessage("\t{0}{1} (Subset)\n", new String('\t', level), component.GetName());
Array array = null;
component.GetDirectlyOwnedObjects(out array);
if (array != null) {
Int32 sheet_number = 0;
foreach (var item in array) {
if (item is Comp.IAcSmSubset) {
ProcessElement(ed, (Comp.IAcSmSubset)item, level + 1);
else if (item is Comp.IAcSmSheet) {
Comp.IAcSmSheet sheet = (Comp.IAcSmSheet)item;
ed.WriteMessage("\t\t{0}{1} (Sheet)", new String('\t', level), sheet.GetName());
sheet.SetNumber(sheet_number.ToString()); // I get an exception here!
++sheet_number;
else if (item is Comp.IAcSmPersist) {
Comp.IAcSmPersist persist = (Comp.IAcSmPersist)item;
ed.WriteMessage("\t\t{0}Additional info: {1}", new String('\t', level), persist.GetTypeName());
else {
ed.WriteMessage("\t\t{0}Unknown object: {1}", new String('\t', level), item.GetType().ToString());
ed.WriteMessage("\n");
