Author Topic: Setfunhelp: call a HTML in standard browser?  (Read 1784 times)
Peter2
« on: March 25, 2019, 08:25:32 AM »
I have these code-lines, taken from online-line:
  1. (defun c:test()
  2.      (getstring "Press F1 for help on the test command:")
  3. )
  4. (setfunhelp "c:test" "d:/temp.html")
Works (nearly) as expected, but it calls the "AutoCAD Browser" to display the HTML instead of my standard browser. I accept that this is a feature and not a bug, but nevertheless - due to compatibility and functionality reasons - I would prefer that the "standard browser" is invoked.
Any simple ways to get it (to avoid startapp and sub-routines and ...) ???
Peter
BricsCAD V23
mkweaver
Re: Setfunhelp: call a HTML in standard browser?
« Reply #1 on: April 15, 2019, 03:04:30 PM »
Try this:
  1.      (setq
  2.        objShell (vla-getinterfaceobject(vlax-get-acad-object) "wscript.shell")
  3.        Run (vlax-invoke objShell 'RUN FileName 5)
  4.        )
  5.      (vlax-release-object objShell)
With FileName set to your html file
Peter2
« Reply #2 on: April 23, 2019, 05:57:49 AM »
Thanks mkweaver
the code works fine to call a defined html-file just now. But this is not what "setfunhelp" does - to define a file in background which is called via F1..
Peter
BricsCAD V23
