Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
help locating a code to draw arc length
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: help locating a code to draw arc length (Read 1715 times)
andrew..
Newt
on:
March 20, 2019, 03:05:26 PM »
a few years ago there was code shared that draws arc length based on numeric input.
I can not seem to located it here.
Would anyone happen to have a copy of it they can share?
thanks
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: help locating a code to draw arc length
Reply #1 on:
March 20, 2019, 03:37:51 PM »
I've found something posted by I think @gile at autodesk forums... It's based on Newton's formula :
Code - Auto/Visual Lisp:
[Select]
defun
c:arcstptenptlength
ArcStartEndLength p1 p2 len
defun
ArcStartEndLength
startPoint endPoint arcLength
newton chord ang rad mid cen
;; use the Newton method to compute the arc half angle according to its length and chord
defun
newton
arc chord
k x
setq
k
chord arc
x
sqrt
6
6
k
repeat
6
setq
x
x
sin
x
k x
cos
x
k
setq
chord
distance
startPoint endPoint
if
chord arcLength
progn
setq
ang
newton arcLength chord
rad
abs
chord
2
sin
ang
mid
mapcar
lambda
p1 p2
p1 p2
2.0
startPoint
endPoint
if
equal
pi
2
ang 1e
009
setq
cen mid
rad
chord
2
setq
cen
polar
mid
angle
startPoint endPoint
pi
2
rad
cos
ang
entmakex
list
cons
0
"ARC"
cons
10
cen
cons
40
rad
cons
50
angle
cen startPoint
cons
51
angle
cen endPoint
setq
p1
getpoint
\n
Pick or specify start point of arc : "
setq
p2
getpoint
\n
Pick or specify end point of arc : "
initget
7
setq
len
getdist
strcat
\n
Pick or specify arc length (must be larger than : "
rtos
distance
p1 p2
2
20
while
len
distance
p1 p2
prompt
\n
Arc length must be larger than : "
princ
rtos
distance
p1 p2
2
20
prompt
"... Pick or specify length again : "
setq
len
getdist
princ
HTH., M.R.
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
gile
Gator
Marseille, France
WWW
Reply #2 on:
March 20, 2019, 03:42:31 PM »
There was also
this reply
Logged
Seagull
London, England
WWW
Reply #3 on:
March 20, 2019, 05:48:51 PM »
Here's another:
https://www.cadtutor.net/forum/topic/43920-can%C2%B4t-draw-a-correct-arc-lengthplease-help/?do=findComment&comment=359272
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
