I thought I saw this answered somewhere but here you go again Code - Auto/Visual Lisp: [Select](if (setq s (ssget "_X" '((0 . "VIEWPORT") (-4 . "!=") (69 . 1)))) (mapcar 'print (mapcar '(lambda (x) (cdr (assoc 410 (entget x)))) (mapcar 'cadr (ssnamex s)))))
?? Other than this one ?Quote from: ronjonp on March 20, 2019, 04:42:01 PMI thought I saw this answered somewhere but here you go again Code - Auto/Visual Lisp: [Select](if (setq s (ssget "_X" '((0 . "VIEWPORT") (-4 . "!=") (69 . 1)))) (mapcar 'print (mapcar '(lambda (x) (cdr (assoc 410 (entget x)))) (mapcar 'cadr (ssnamex s)))))
>>>>I checked the email from the swamp I find out that there are 2 threads posted with the same subjectSorry for conflictIs there a way to combine the 2 threads?
Quote from: HasanCAD on March 21, 2019, 05:14:39 AM>>>>I checked the email from the swamp I find out that there are 2 threads posted with the same subjectSorry for conflictIs there a way to combine the 2 threads?Done.
