Author Topic: Adding an Alert if dwg is not available  (Read 1517 times)
MSTG007
« on: March 20, 2019, 07:59:11 AM »
I have a dialog box that has a button for each county in the state. I do not have all the counties created yet.
How can I place an if statement that allows for a alert box to appear "county dwg is not completed yet..." if the dwg that it is pulling does not exist?
(defun c:adams()
(defun open_dwg_read_only (ad fna)(if (findfile fna)(vla-activate (vla-open ad fna :VLAX-TRUE))))
(open_dwg_read_only (vla-get-documents (vlax-get-acad-object)) "\\\\server\\Adams\\Adams_Co_GIS_SPE_SHP.dwg")
I have about 10 out of 90 done lol.
Thank you for any pointers.
Civil3D 2020
Re: Adding an Alert if dwg is not available
« Reply #1 on: March 20, 2019, 08:51:53 AM »
Since you are already testing whether or not the file exists using findfile, simply add an alert expression as the 'else' argument of the if statement.
(defun open_dwg_read_only (ad fna) (if (findfile fna) (vla-activate (vla-open ad fna :VLAX-TRUE)) (alert (strcat fna " doesn't exist."))))
MSTG007
« Reply #2 on: March 20, 2019, 08:55:35 AM »
Thank you Lee. Something so simple. Seriously thank you!
Civil3D 2020
