Author Topic: CHANGE DRAWING UNITS LISP  (Read 3062 times)
pedroantonio
« on: March 15, 2019, 05:54:54 AM »
hi. I am using a lot of drawings and all the tine  i need to check the drawing units because there  are wrong. For example we are working in meters  bun in the setting is feet or inches , and if i insert a block or xref i have probles with the scales. So i want a lisp to change the drawing setting to this
Dlanor
Re: CHANGE DRAWING UNITS LISP
« Reply #1 on: March 15, 2019, 07:23:55 AM »
System variables that control drawing units :
AUNITS - controls angular units.  Set to 2 for grads
AUPREC - Angular unit precision. Set to 4
ANGDIR - Angle direction.  Set to 1 for clockwise
ANGBASE - Sets the base angle to 0 with respect to the current UCS. For North this will be (/ pi 2)
LUNITS - controls Length units. Set to 2 for decimal
LUPREC - Length precision. Set to 3
INSUNITS - Specifies a drawing-units value for automatic scaling of blocks, images, or xrefs inserted or attached to a drawing. Set to 6 for metres.
(mapcar 'setvar (list 'aunits 'auprec 'angdir 'angbase 'lunits 'luprec 'insunits) (list 2 4 1 (/ pi 2) 2 3 6))
pedroantonio
« Reply #2 on: March 15, 2019, 08:11:05 AM »
Thank you Dlanor
MeasureUp
« Reply #3 on: March 18, 2019, 11:53:57 PM »
You may also consider these SV below:
  • measureinit
  • measurement
  • unitmode
HTH
