I am putting together a drawing of a county with shapefiles within Autodesk MAP. I decided to do one county before I did the rest of the counties within the State. Then use this as a master to save out.
Inside the Task Pane, I have several shapfiles that are formatted visually; the way I would like to see them. I can save out these out as (.layers) files of each one.
I am wondering if its possible to take the saved (.layers) files and perform a find and replace on the file names and the contents within the (.layers) file that can be read with a text editor?
For instance, Marion_Co_Lakes_SPE, I would like to find and replace the "Marion" part with "Madison". Then perform the same step on the other (.layers) files.
