Author Topic: readdwgfile architectural - format units  (Read 1706 times)
autogis
« on: March 11, 2019, 04:28:53 PM »
Using Map3d 2018/Objectarx, I am trying to import a file that is in Architectural/Inches scale (under format --> units) into an existing file:
Database db = new Database(false, true);
db.ReadDwgFile(the_file, System.IO.FileShare.ReadWrite, true, "");
However the drawing imported does not display in the correct scale.  How can I set it to Architectural/Inches scale when importing?
Thank you
