Author Topic: Edit Text After restarting the PC  (Read 3042 times)
MSTG007
« on: March 11, 2019, 07:07:15 AM »
Just wanting to know, Why is it when I first start CAD in the morning. I open a drawing and then try to edit CAD via the Mtext editor or text editor, it takes seconds. After that its normal again. Its not a big deal, just curious why it does this.
Civil3D 2020
Re: Edit Text After restarting the PC
« Reply #1 on: March 11, 2019, 12:34:52 PM »
Curious,
IF  you start autocad, then close it and restart autocad does the symptom persist?
dgorsman
« Reply #2 on: March 11, 2019, 12:38:07 PM »
There's a demand-load for the text editor in there somewhere.  It doesn't load until you uses it to edit something.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #3 on: March 11, 2019, 12:39:54 PM »
which could suggest he add it to the startup suite, maybe?
MSTG007
« Reply #4 on: March 11, 2019, 12:44:36 PM »
I removed my appload routine. It still seems to do lag. Interesting thought. Maybe I should try to reset CAD and see how it acts.
Civil3D 2020
dgorsman
« Reply #5 on: March 11, 2019, 06:00:32 PM »
It wouldn't be APPLOAD.  Check under HKLM for the demand load switch, which is likely set as "on command".  Try changing it to "on start up".
try {GreatPower;}
   finally
      {MasterBasics;}
