Hi all,
I have a command that calculate the area of differents objets. You can either select object one by one or with a selection set.
One by one is working fine, Solid3D are detect but for selection set is not working. I'm not sure what I'm doing wrong..
One by one (working fine) :
PromptEntityOptions opts = new PromptEntityOptions("Sélectionner des objets");
opts.SetRejectMessage(RESM.getText("NoLinePline", UTIL.cUtLang));
opts.AddAllowedClass(typeof(Polyline), false);
opts.AddAllowedClass(typeof(Circle), false);
opts.AddAllowedClass(typeof(Spline), false);
opts.AddAllowedClass(typeof(Solid3d), false);
PromptEntityResult per = ed.GetEntity(opts);
Selection set (not working for solid3d, but for pline and every othre it's working fine) :
TypedValue[] values = new TypedValue[] { new TypedValue((int)DxfCode.Start, "LINE,ARC,CIRCLE,POLYLINE,SPLINE,ELLIPSE,LWPOLYLINE,SOLID3D,SOLID") };
SelectionFilter filter = new SelectionFilter(values);
PromptSelectionOptions SelOpts = new PromptSelectionOptions();
Utils.SetFocusToDwgView();
SelOpts.AllowDuplicates = false;
SelOpts.MessageForAdding = RESM.getText("SelObj", UTIL.cUtLang);
SelOpts.MessageForRemoval = "Désélectionner objet";
PromptSelectionResult res = ed.GetSelection(SelOpts, filter);
Thank you
