The test.lsp draws polyline from file. The test.txt file contain the chainage and the elevetion. But the elevetions is allready ( elevetion * 10) because the vertical exaggeration must be 10.
In the last version of qp.lsp when we select the center line and the contours the lisp draws the ground line with the chainage and the elevetion.
The vertical exaggeration is important because some times must be 1 .
The problem is that i dont have contours any time and i need to draw a Center-Line profile from a file like test.txt. And some times i need to add a second ground from file or to draw the second ground and print the elevetion and chainage (without 0+ ...... (for example 0 + 250) , only the numbe (for example 250))
if it helps i use test table.dwg under the ground lines
