Author Topic: Which DLL should I refer to in order to use the AcMapMapMap class?  (Read 1723 times)
gswang
The code I found online, as shown below, which DLL should I refer to in order to use the AcMapMapMap class?
// Get the Map Object
AcMapMap currentMap = AcMapMap.GetCurrentMap();
Double viewScale = currentMap.GetViewScale();
ed.WriteMessage("ViewScale Before Change : " + viewScale.ToString());
// set the ViewScale
viewScale = (viewScale / 100);
currentMap.SetViewScale(viewScale);
ed.WriteMessage("ViewScale After Change : " + viewScale.ToString());
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Which DLL should I refer to in order to use the AcMapMapMap class?
« Reply #1 on: March 02, 2019, 02:39:23 PM »
Does anything in these help ? https://adndevblog.typepad.com/infrastructure/2013/05/autocad-map-3d-api-training-content-part-6.html
The Code solution linked in the article has a list of references ... perhats those will help.
Called Kerry in my other life
I live at UTC + 13.00
