((((((((nil 20.2771 10.3859 0.0) 20.9515 9.64759 0.0) 21.6259 8.90925 0.0) 22.3004 8.1709 0.0) 22.9748 7.43256 0.0) 23.6492 6.69422 0.0) 24.3236 5.95587 0.0) 24.791 6.38282 0.0)
(setq dtlst (cons ps p1n))
(setq dtlst (cons p1n dtlst))
(setq lst (list p1 p2))(setq objs (ssget "F" lst (list (cons 0 "line"))))
If you use the fence option in your ssget it will pick objects in order. you have pt1 pt2 Code: [Select](setq lst (list p1 p2))(setq objs (ssget "F" lst (list (cons 0 "line"))))
Thanks Tharwat have had that happen in day to day stuff. Its another of those frustrating Autocad lisp bugs.
