Author Topic: create a boundary around solid hatch  (Read 5310 times)
jtm2020hyo
« on: February 22, 2019, 10:50:24 PM »
I need to create a boundary around all solid hatch inside the drawing (nested/dynamic/regular blocks and external solid hatch)
Re: create a boundary around solid hatch
« Reply #1 on: February 23, 2019, 07:32:17 AM »
Crank
« Reply #2 on: February 23, 2019, 09:42:44 AM »
jtm2020hyo
« Reply #3 on: February 24, 2019, 11:31:46 AM »
https://jtbworld.com/autocad-hatchb-lsp
I tried "HATCHB.LSP Free AutoLISP for AutoCAD" but I actually does not work with SOLIDs
jtm2020hyo
« Reply #4 on: February 24, 2019, 11:34:07 AM »
https://goo.gl/CZCXUx
0 results for a lisp-routine to generate  BOUNDARY polyline around a SOLID
« Reply #5 on: February 24, 2019, 07:36:31 PM »
You asked for boundary around solid hatch then asked for boundary around a solid? Which is it?
jtm2020hyo
« Reply #6 on: February 25, 2019, 09:29:18 AM »
mmm... it's not the same?
« Reply #7 on: February 25, 2019, 09:42:12 AM »
A SOLID is different object than a SOLID hatch.
jtm2020hyo
« Reply #8 on: February 27, 2019, 09:11:23 AM »
my request is for the SOLID.
I need to generate polyline around SOLID in nested blocks and find another code-routine to delete them all.
hmspe
« Reply #9 on: February 27, 2019, 05:12:57 PM »
"Science is the belief in the ignorance of experts." - Richard Feynman
« Reply #10 on: February 28, 2019, 11:48:10 AM »
Here's a version of that code without command calls. If you want it to work on your example drawing at the Autodesk forum, explode all your blocks.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/create-a-boundary-around-solid-hatch/m-p/8619452#M381543
  1. (defun c:foo (/ a b c d s)
  2.   ;; RJP » 2019-02-28
  3.   ;; Trace solids and delete
  4.   (if (setq s (ssget ":L" '((0 . "solid"))))
  5.     (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  6.       (setq a (vl-remove-if-not '(lambda (x) (vl-position (car x) '(10 11 12 13))) (entget e)))
  7.       (mapcar 'set '(a b c d) (mapcar 'cdr a))
  8.       (entmakex (list '(0 . "LWPOLYLINE")
  9.                       '(100 . "AcDbEntity")
  10.                       (assoc 8 (entget e))
  11.                       '(100 . "AcDbPolyline")
  12.                       '(90 . 4)
  13.                       '(43 . 0)
  14.                       '(70 . 1)
  15.                       (cons 10 a)
  16.                       (cons 10 b)
  17.                       (cons 10 d)
  18.                       (cons 10 c)
  19.                       (assoc 210 (entget e))
  20.                 )
  21.       )
  22.       (entdel e)
  23.     )
  24.   )
  25.   (princ)
  26. )
Dilan
« Reply #11 on: March 11, 2019, 04:19:11 AM »
Link to source code.https://jtbworld.com/autocad-hatchb-lsp
Note that code with a copy write should not be posted without the authors permission.Please post a link to the source instead.
« Last Edit: March 11, 2019, 09:27:04 AM by CAB »
jtm2020hyo
« Reply #12 on: March 21, 2019, 04:41:00 PM »
Perhaps post #3 in http://www.theswamp.org/index.php?topic=45099.msg502994#msg502994
In your link, I found the solution for solid...
...but what about SOLIDs in NESTED BLOCKs, Dynamics BLOCKS and Regular blocks?
« Last Edit: March 21, 2019, 05:20:42 PM by jtm2018hyo »
