Author Topic: mLeader LISP Issue  (Read 4691 times)
cmwade77
mLeader LISP Issue
« on: February 22, 2019, 06:56:21 PM »
This is one very small snipet of code from a routine I am currently working on. I am having errors when trying to insert text after changing content type from block to mtext.
(defun c:mletest (/ Ent1 *mlObj* *Text*)
    (while (not Ent1)
        (setq Ent1 (entsel "\rPlease select mleader:"))
    (setq *mlObj* (vlax-ename->vla-object (car Ent1)))
    (if (= (vla-get-contenttype *mlObj*) acblockcontent)
           (vla-put-contenttype *mlObj* acmtextcontent)
           (setq *Text* (getstring T "\nEnter text:"))
            (if *Text*
                (vla-put-TextString *mlObj* *Text*)        ;******** This line seems to cause the mleader to be erased or to return an error of Description Not Provided
                (vla-put-TextString *mlObj* "TEMP\\PTEXT") ;******** This line seems to cause the mleader to be erased or to return an error of Description Not Provided
You will find the error occurs after entering text, perhaps someone can tell me what I am doing wrong.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: mLeader LISP Issue
« Reply #1 on: February 22, 2019, 09:02:18 PM »
Does the Leader disappear or the Text ??
And only when you hit ENTER or SPACE at the Prompt ??
ENTER or SPACE using the T flag sets *text* as an empty String ie ""
So the if will not fail and will attempt to use the empty string as the MText value ...
Just a wild guess ...
otherwise, can you post the drawing with the original Multileader please.
ADDED:
I wonder if you need to actually change the MleaderStyle from one with a block to one with MText ???
« Last Edit: February 22, 2019, 09:30:00 PM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
cmwade77
« Reply #2 on: February 25, 2019, 12:17:29 PM »
It doesn't matter if there is a space in the text or not, it doesn't work either way. Yes, I would expect an empty string to fail, as I said this is just one small piece of code, I actually have checks in place to make sure the string isn't empty in the full code.
The style never changes no matter if it is a block or mtext.
I have attached a drawing with the original mleader in it, the ones with the blocks can't seem to be changed to having MTEXT and I am not sure why.
« Reply #3 on: February 25, 2019, 04:28:24 PM »
Did you ever get this to work? I'd imagine you can't just change the content type .. I get strange results here ( no contents property ).
cmwade77
« Reply #4 on: February 25, 2019, 04:29:50 PM »
You can change to a block, but changing back to mText is where there seems to be a problem.
« Reply #5 on: February 25, 2019, 04:41:51 PM »
The mleader definitely does not like the change from block to mtext type:
cmwade77
« Reply #6 on: February 25, 2019, 05:27:17 PM »
Well, I decided to roll my own method of making this work. Basically, this creates a new leader using the same properties as the existing leader, then erases the old leader. It is a bit of a kludge, but it works as near as I can tell.
(defun c:mletest (/ Ent1 *mlObj* *Text* *NewMlObj*)
    (while (not Ent1)
            (setq *NewMlObj* (MleaderBlockToMtext *mlObj* *Text*))
            (if *NewMlObj*
                (setq *mlObj* *NewMlObj*
                      *NewMlObj* nil
(defun MleaderBlockToMtext (*MlObj* *Text* / *ThisDrawing* *Space* *NewMlObj* *InsPt* NewPoints2 *Pt1* *FxPt* *MtObj* *ArrowheadSize* *ArrowheadType* *DogLegged* *DogLegLength* *EntityTransparency* *LandingGap* *Layer* *LeaderLineColor* *LeaderLineType* *LeaderLineWeight* *LeaderType* *Linetype* *LinetypeScale* *Lineweight* *PlotStyleName* *StyleName* *TextWidth* *NewPoints*)
;Written by: Chris Wade - 02/25/2019
;Changes leader content from Block to mText
;Usage: (setq *NewMlObj* (MleaderBlockToMtext *mlObj* *Text*))
    (if *MlObj*
            (setq *ThisDrawing* (vla-get-activedocument (vlax-get-acad-object)) ;_ Set Drawing and Space
              *Space* (vlax-get-property *ThisDrawing* (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)); Code adjustment from Lee Mac at: http://www.theswamp.org/index.php?topic=54349.msg589159#msg589159
            (setq *ArrowheadSize* (vla-get-ArrowheadSize *MlObj*)
                  *ArrowheadType* (vla-get-ArrowheadType *MlObj*)
                  *DogLegged* (vla-get-DogLegged *MlObj*)
                  *DogLegLength* (vla-get-DogLegLength *MlObj*)
                  *EntityTransparency* (vla-get-EntityTransparency *MlObj*)
                  *LandingGap* (vla-get-LandingGap *MlObj*)
                  *Layer* (vla-get-Layer *MlObj*)
                  *LeaderLineColor* (vla-get-LeaderLineColor *MlObj*)
                  *LeaderLineType* (vla-get-LeaderLineType *MlObj*)
                  *LeaderLineWeight* (vla-get-LeaderLineWeight *MlObj*)
                  *LeaderType* (vla-get-LeaderType *MlObj*)
                  *Linetype* (vla-get-Linetype *MlObj*)
                  *LinetypeScale* (vla-get-LinetypeScale *MlObj*)
                  *Lineweight* (vla-get-Lineweight *MlObj*)
                  *PlotStyleName* (vla-get-PlotStyleName *MlObj*)
                  *StyleName* (vla-get-StyleName *MlObj*)
                  *TextWidth* 0
                  *NewPoints* (vlax-make-safearray vlax-vbDouble '(1 . 6))
                  *NewPoints* (vla-GetLeaderLineVertices *mlObj* 0)
                  NewPoints2 (vlax-safearray->list (vlax-variant-value *NewPoints*))
                  *Pt1* (list (nth 0 NewPoints2) (nth 1 NewPoints2) (nth 2 NewPoints2))
      *FxPt* (list (nth 3 NewPoints2) (nth 4 NewPoints2) (nth 5 NewPoints2))
                  *NewMlObj* (vla-AddMLeader *Space* *NewPoints* 0)
            (if *NewMlObj*
                    (if (> (car *Pt1*) (car *FxPt*))
                            (vla-put-dogleglength *NewMlObj* 0); This code is from http://www.theswamp.org/index.php?topic=31348.msg369336#msg369336
                    (vla-SetDogLegDirection *NewMlObj* 0 (vlax-3D-point (list (if (<= (car *pt1*) (car *FxPT*)) 1 -1) 0 0))); Code from: http://www.theswamp.org/index.php?topic=30817.0
                    (vla-put-dogleglength *NewMlObj* *DogLegLength*); This code is from http://www.theswamp.org/index.php?topic=31348.msg369336#msg369336
(vla-put-textstring *NewMlObj* *Text*)
    (vla-put-TextJustify *NewMlObj* acAttachmentPointTopRight)
                    (vla-put-StyleName *NewMlObj* *StyleName*)
                    (vla-put-ArrowheadSize *NewMlObj* *ArrowheadSize*)
                    (vla-put-ArrowheadType *NewMlObj* *ArrowheadType*)
                    (vla-put-EntityTransparency *NewMlObj* *EntityTransparency*)
                    (vla-put-LandingGap *NewMlObj* *LandingGap*)
                    (vla-put-Layer *NewMlObj* *Layer*)
                    (vla-put-LeaderLineColor *NewMlObj* *LeaderLineColor*)
                    (vla-put-LeaderLineType *NewMlObj* *LeaderLineType*)
                    (vla-put-LeaderLineWeight *NewMlObj* *LeaderLineWeight*)
                    (vla-put-Linetype *NewMlObj* *Linetype*)
                    (vla-put-LinetypeScale *NewMlObj* *LinetypeScale*)
                    (vla-put-Lineweight *NewMlObj* *Lineweight*)
                    (if (= (getvar "PSTYLEMODE") 0)
                        (vla-put-PlotStyleName *NewMlObj* *PlotStyleName*)
                    (vla-SetLeaderLineVertices *NewMlObj* 0 *NewPoints*)
                    (vla-delete *MlObj*)
            *NewMlObj*
« Reply #7 on: February 25, 2019, 06:05:20 PM »
Off topic question, but why do you use *var*  for all your variables? I've always interpreted that naming convention as a global.
cmwade77
« Reply #8 on: February 25, 2019, 06:09:35 PM »
It is actually part of a larger routine where I am using them as a naming convention for a specific reason. Basically in my larger routine the *var* represent items that get reused throughout the routine and complimentary routines, so basically I guess they are global variables, you just don't get to see that in the small extract and I kept the variable names consistent so that I wouldn't have to go back and change them all to incorporate into my larger routine.
kdub_nz
  • SuperMod
« Reply #9 on: February 25, 2019, 09:37:45 PM »
Ditto me Ron. Usually for variables that are static.
I use a unique prefix for project specific globals ... makes it easy to audit or nullify.
kdub_nz
  • SuperMod
« Reply #10 on: February 25, 2019, 09:42:42 PM »
I came to the conclusion that I'd do it the same way.
« Reply #11 on: February 26, 2019, 10:28:53 AM »
Cool .. FWIW you could simplify your properties get and set with something like so:
  1. (setq ml (vlax-ename->vla-object (car (entsel))))
  2. ;; Get vals
  3. (setq v (mapcar '(lambda (x) (cons x (vlax-get ml x)))
  4.                 '(arrowheadsize     arrowheadtype     doglegged         dogleglength
  5.                   entitytransparency                  landinggap        layer
  6.                   leaderlinecolor   leaderlinetype    leaderlineweight  leadertype
  7.                   linetype          linetypescale     lineweight        plotstylename
  8.                   stylename         textwidth
  9.                  )
  10.         )
  11. )
  12. (setq newml (vlax-ename->vla-object (car (entsel))))
  13. ;; Set vals on new mleader
  14. (mapcar '(lambda (x) (vl-catch-all-apply 'vlax-put (list newml (car x) (cdr x)))) v)
cmwade77
« Reply #12 on: February 27, 2019, 02:27:56 PM »
Cool, thank you, some of those properties won't work that way due to bugs in how LISP handles mLeaders in AutoCAD (particularly the dogleglength), but many will.
cmwade77
« Reply #13 on: March 04, 2019, 01:02:17 PM »
I am getting more of the routine down, although I still haven't implemented ronjonp's suggestion yet, but I am having and issue where text gets reset when cycling from the mtext content type to a block style.
I have attached the LISP routine and the required drawing here if someone can help me figure out where the issue is, I would greatly appreciate it.
Here is a video of the problem:
https://autode.sk/2C6QGo2
« Last Edit: March 04, 2019, 01:11:16 PM by cmwade77 »
