Author Topic: is there solution hatch entry to region entry ?  (Read 1423 times)
dussla
« on: February 20, 2019, 11:48:09 PM »
Hi
I'm going to ask about features I can not handle
If you look at the attachment, there is a hatch file.
I want to completely transform it into a region object
This is not an area I can approach.
I would like to ask you for a good tool or custom for this problem
Dlanor
Re: is there solution hatch entry to region entry ?
« Reply #1 on: February 21, 2019, 08:14:34 AM »
I would suggest using the hatchgenerateboundary command. You can type it once then select all the hatches and it will generate closed lwpolylines for each hatch. You can then use the closed polylines to generate the regions. The only problem i forsee is that the drawing has hatches on top of hatches.
dussla
« Reply #2 on: February 21, 2019, 09:27:04 AM »
Wow thank you
I will try
Really thnak you
