Author Topic: vlisp-compile returns 1, 2, ...4  (Read 2714 times)
@_Bilal
  • Mosquito
« on: February 16, 2019, 04:48:09 PM »
Greetings,
The vlisp-compile as per Autodesk Knowledge networks
Return Values
Type: T or nil
T, if compilation is successful; otherwise nil.
in this example vlisp-compile return 2!   why 2?
these two lisp files run correctly
sum24.lsp
(defun sum24 ( a b / )
   (setq result
      (+ (* 2 a) (* 4 b))
);sum24
score.lsp
(defun score ( arg1 arg2 / func funcid)
   (setq funcid
      (eval
         (read (strcat arg1 arg2))
   (funcid 4 5)
);score
When compiling score.lsp to fas
(vlisp-compile 'st "C:\\......\\score.LSP")
the return of vlisp-compile is 2
is someone have an explanation of what happened?  where is the error?
thank you
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: vlisp-compile returns 1, 2, ...4
« Reply #1 on: February 16, 2019, 05:51:53 PM »
The compiler is reporting the quantum of warnings it produces.
In this case :
; warning: run time evaluated expression: (READ (STRCAT ARG1 ARG2))   <<== caused by the EVAL I assume
; warning: local variable used as function: FUNCID
If you modify sum24 to
  1. (defun sum24 (a b / ) (setq result (eval (+ (* 2 a) (* 4 b)))) )
you will get 3 returned from the compiler.
As an aside :
The score function will generate a runtime error because you are passing integers to be evaluated as strings.
Called Kerry in my other life
I live at UTC + 13.00
@_Bilal
  • Mosquito
« Reply #2 on: February 16, 2019, 07:10:05 PM »
  1. (defun sum24 ( a b / )
  2.         (setq result
  3.                 (+ (* 2 a) (* 4 b))
  4.         )
  5. );sum24
  6.
  7.
  8. (defun score ( arg1 arg2 / func funcid)
  9.         (setq funcid
  10.                 (eval
  11.                         (read (strcat arg1 arg2))
  12.                 )
  13.         )
  14.         (funcid 4 5)
  15. );score
  16.
  17. ;|
  18. In AutoCAD commandline
  19.      command: (sum24 4 5)
  20.      28
  21.
  22.      The arguments passed to function score are string not integers
  23.      command: (score "sum" "24")
  24.      28
  25.
  26. These two functions run properly....!
  27. when compiling score.lsp
  28.      command: (vlisp-compile 'st "C:\\Folders\\score.LSP")
  29.      2
  30.    ............!
  31.
  32. I am trying to run the first function sum24 from score function, the name of the first function is variable
  33. let say we have a lot of function sum24, sum34, sum38........ How to run these functions from score function?
  34.
  35. |;
  36.
  37.
kdub_nz
  • SuperMod
« Reply #3 on: February 16, 2019, 07:41:24 PM »
Something like :-- ??
  1. (defun sum24 (a b / ) (setq result (+ (* 2 a) (* 4 b))) )
  2. (defun sum25 (a b / ) (setq result (+ (* 2 a) (* 5 b))) )
  3. (defun sum26 (a b / ) (setq result (+ (* 2 a) (* 6 b))) )
  4. (defun sum27 (a b / ) (setq result (+ (* 2 a) (* 7 b))) )
  5.
  6.
  7. (defun score (arg1 arg2 valA valB/)
  8.   (eval (read (strcat "(" arg1 arg2 " " (itoa valA) " " (itoa valB) ")")))
  9. )
  10.
_$ (score "sum" "24" 4 2)
16
_$ (score "sum" "25" 4 2)
18
_$ (score "sum" "26" 4 2)
20
_$ (score "sum" "27" 4 2)
22
« Last Edit: February 16, 2019, 08:31:51 PM by kdub »
@_Bilal
  • Mosquito
« Reply #4 on: February 16, 2019, 08:16:36 PM »
  1. (defun score (arg1 arg2 valA valB/)
  2.   (eval (read (strcat "(" arg1 arg2 " " (itoa valA) " " (itoa valB) ")")))
  3. )
  4.
  5. ;;           When compiling score.lsp
  6.
  7. ;;     command: (vlisp-compile 'st "C:\\Folders\\score.LSP")
  8. ;;      1
  9. ;;      The compilation return 1, does 1 means an error or not? because according to Autodesk help the vlisp-compile should return T if success
  10.
  11.
Thank you for your cooperation
kdub_nz
  • SuperMod
« Reply #5 on: February 16, 2019, 08:38:26 PM »
;;      1
Please re-read my first post.
This is a warning (advisory ), NOT an error
@_Bilal
  • Mosquito
« Reply #6 on: February 17, 2019, 09:46:48 AM »
Thank you Kdub for the detailed explanation, maybe my question wasn't clear enough
The vlisp-compile of the below codes returns T without warning.
  2.         (setq result
  4.         )
  5. );sum24
  6.
  7. (sum24 4 5)   ; Return 28
  8.
  9. ;;      Compile sum24.lsp
  10.         (vlisp-compile 'st "C:\\...............\\sum24.LSP")      ; Return T without warning
  11.
  12.
  13.
  14. (defun score ( arg1 arg2 / )
  15.         ((vl-symbol-value (read (strcat arg1 arg2))) 4 5)
  16. );score
  17.
  18. (score "sum" "24")    ; Return  28
  19.
  20. ;;      Compile score.lsp
  21.         (vlisp-compile 'st "C:\\...............\\score.LSP")       ; Return T  without warning
  22.
  23.
kdub_nz
  • SuperMod
« Reply #7 on: February 17, 2019, 02:44:21 PM »
Your question was perfectly clear.
I have no intimate knowledge of the inner workings of the compile functionality and can only guess why the AutoCad documentation does not align with reality.
Perhaps you could express your concerns to AutoDesk by submitting a support ticket.
I like your use of vl-symbol-value. ... much more elegant than the solution I cobbled together.
@_Bilal
  • Mosquito
« Reply #8 on: February 17, 2019, 03:56:28 PM »
Thank you Kdub for your cooperation.
Really, theswamp site get below the surface
