Author Topic: wrote this program...what can i do to make it better  (Read 4559 times)
dubb
« on: June 08, 2005, 04:32:36 PM »
i wrote this program, however i think i can make it better. i want to make the line all as one peice. and then prompt me to add dtext as a part of the leader. as time goes im getting a little more comforable about writing programs but i dont want to get comfortable with the wrong practices.
;;Wynn Engineering Inc.
;;leaderloop.lsp file CREATED BY SOUK
;;souksavanh nomichith
;;last update 06-07-05
(defun c:ll (/ pt1 pt2 scl pt3)
  (princ "Leader loop.....")
  (setq scl (getvar "dimscale"))
  (setq pt1 (getpoint "\nPick first point: ")
  pt2 (getpoint pt1 "\nPick second point: ")
pt3 (getpoint pt2 "\nPick third point: ")
  (command "pline" pt1 pt2 pt3 "" "insert" "loop" pt1 scl scl (* 180.0 (/ (angle pt1 pt2) pi)))
here is the file associated with this program
http://www.theswamp.org/lilly_pond/dubb/loop.dwg?nossi=1
David Hall
  • Automatic Duh Generator
« Reply #1 on: June 08, 2005, 04:51:10 PM »
a few things I would do is capture a few setvars, mod them and put them back when you are done.  For instance, is the second line "supposed" to be horizontal as it goes into the text?
David Hall
« Reply #2 on: June 08, 2005, 04:52:41 PM »
This is what I did
(defun C:LOOP (/ COLOR P1 P2 P3 SIZE)
 (setq ortho  (getvar "orthomode")
cecho (getvar "cmdecho")
osm    (getvar "osmode")
  (setvar "orthomode" 0)
  (setvar "cmdecho" 0)
  (setvar "OSMODE" 0)
  (setq SIZE (getvar "dimscale"))
  (setq P1 (getpoint "\nSelect first point "))
  (setvar "orthomode" 1)
  (command "pline" P1)
  (setq P2 (getpoint P1 "\nNext point "))
  (command "w" 0 0 P2)
  (setq P3 (getpoint P2 "\nLast point "))
  (command P3 "")
  (command "insert" "loop" P3 SIZE "" P2)
  (setvar "orthomode" ortho)
  (setvar "cmdecho" cecho)
  (setvar "OSMODE" osm)
dubb
« Reply #3 on: June 08, 2005, 05:35:53 PM »
Quote from: CmdrDuh
yes the second line should be horizontal with a dtext beside it. is it possible to have the loop with the line as one object or polyline?
« Reply #4 on: June 08, 2005, 06:17:34 PM »
Ask yourself questions like "What happens if the user doesn't pick the first point, or subsequent points etc." Does the program handle it gracefully or do a face plant? What impacts do various settingd, like units, cmdecho etc. have on performance / display? What can I do to bomb / PEBKAC proof it? Can any portions be rewritten so they could be re-used? Have I written this in a manner which would make it a no brainer for me to quickly understand the program a year from now? Etc.
dubb
« Reply #5 on: June 15, 2005, 01:20:12 PM »
Quote from: MP
exactly, now i just need to find out how to trap the program so that it will have a positive output no matter what happens rather than an error. btw what the hell is PEBKAC?...ill just google it.
« Reply #6 on: June 15, 2005, 02:13:38 PM »
Dubb,
In keeping with MP words of wisdom...
One thing I like to do in my progys is to make 'stronger' support procedures for myself. I love to take the "preventive error traping" approach to alot of my apps. This dosent mean that I dont supply an error trap it just means that I have that much less to do when I do add the trap.
So that being said; I will toss this up here and hope you will ask T O N S of questions about it. When you think you got a good handle on it we can apply this "method" to some other aspects of your program if you would like.
(defun getpoin7 ()
  ;; Start a loop to keep going untill test condition evaluates to NIL
  (while
    ;; Make a TRUE eval to nil. -- Otherwise tell me the oposite of what really happnens
    (not
       ;; Create a variable and fill it with the results of a getpoint.
      (setq x (getpoint "\nSelect Point: "))
      );_ end not
    ;; If the user didnt pic the point let them know.
     (princ "\nYou did not select a point, please try again. ")
    );_ end while
  ;; When the loop ends make sure we return the good results back to them.
  x
 );_ end defun
dubb
« Reply #7 on: June 15, 2005, 03:14:09 PM »
where is there an "x" here
;;When the loop ends make sure we return the good results back to them.
x
);_ end defun
if the user selects a point then the program ends..right?but if the user hits "enter" or doesnt select a point then the program will continue following the (princ) line. by using "while" and "not"...it allows the the program to evaluate a nil?
CADaver
« Reply #8 on: June 15, 2005, 03:51:40 PM »
And to throw in my 2 cents:
Let the routine setup a child dimstyle for leaders with a user block rather than using a separate pline and block.
« Reply #9 on: June 15, 2005, 05:17:21 PM »
Quote from: dubb
x
);_ end defun
The "x" comes from us creating a variable and filling it up with the result of the "getpoint" function. (Its in the middle of the While-not loop.)
Yes, Would you like to see how you can do this same thing without a "loop"?
dubb
« Reply #10 on: June 15, 2005, 08:14:06 PM »
Quote from: CADaver
thanks man..ill try this way too
Quote from: se7en
i just thought the "x" was in an odd place.
yes it would koo to see this without the a "loop"[/quote]
« Reply #11 on: June 15, 2005, 09:24:26 PM »
Looking at John's code without comments, it looks like this
(defun getpoin7 (/ x)
  (while (not (setq x (getpoint "\nSelect Point: ")))
  x
As you can see the WHILE loop is waiting for a nil value so it can quit.
It gets that value when the user picks a point.
The GETPOINT returns a point value to the SETQ which in turn returns that value
to the NULL. Because the value is not null the NULL returns nil.
This is the null the WHILE was waiting for to exit the loop.
But the WHILE returns the most recent value of the last expression, which is nil.
You want the getpoin7 function to return the point list not the nil value from the WHILE loop.
So you put the x and it does nothing more that return its value, which is the point list
we were looking for.
I hope that was clear enough to follow.
Each lisp function returns something and sometimes it is meaningless like PROMPT or COMMAND always
return nil and has no meaning. But most return a value that can be useful to you as a programmer.
Pay attention to these return values & think creatively. :)
Not very eloquent but I think you will see what I was trying to say.
« Reply #12 on: June 15, 2005, 10:38:15 PM »
Good. This is gonna be very kool! (I think your gonna really like this!)
What we are gonna do is test the same way we did in the previous procedure, but this time instead of re-looping if the condition isnt met, we just start over at the begining. Souds simple huh? Well guess what; people tend to get real confused about this method. In realty its a very simple and easy way to accomplish a task. "If it didnt work this time ...try it again!"
This is a basic programing method called recursion. There are several diff methods and ways to classify recursion, but for now we are gonna concentrate on the simplest form.
For now, we are gonna define recursion as: If a test condition isnt met, call the procedure again. (Later on we can develop a more deeper understanding and definition of recursion. But right now we are just gonna keep it simple. k? good. *lol*)
;;; g3tpoin7
;;; A simple recursive example
(defun g3tpoin7 ( / x)
    x
    (g3tpoin7)
« Reply #13 on: June 16, 2005, 01:31:02 AM »
Before this thread is finished make sure you mention initget too.
/suggestion
dubb
« Reply #14 on: June 16, 2005, 12:01:28 PM »
so this recursion thing....doesnt give any options but to make sure the user does something when the program expects an input. cool....i can really use this method in alot of my routines...since you brought up the word "recursion" i decided to google it....heres what i found
http://mars.cs.unp.ac.za/lisp/lisp5.html
so there is more to you recursion method?
