Author Topic: GetPoint in AutoCAD.Interop  (Read 4257 times)
Nima2018
« on: February 15, 2019, 10:34:33 AM »
I want to use GetPoint via Autodesk.AutoCAD.Interop in my codes, but I get an error about missing object in the following line :
            AcadPoint my_pt1 = default(AcadPoint);
            AcadPoint my_pt2 = default(AcadPoint);
            my_pt1 = AcadApp.ActiveDocument.Utility.GetPoint(, "Please click on the first point :"); // I get error at this line
            my_pt2 = AcadApp.ActiveDocument.Utility.GetPoint(my_pt1, "Please click on the second point :");
However, in VBA such a limitation does not exist for an optional argument.
Also, the reason for using " Introp Com " is that I want to use it in a Windows application project without using Netload command .
Please advice me .
« Last Edit: February 15, 2019, 10:40:26 AM by Nima2018 »
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: GetPoint in AutoCAD.Interop
« Reply #1 on: February 15, 2019, 01:14:00 PM »
What exactly is the error ??
I assume AutoCAD is open and you are trying to talk to it from yourWindows App. ??
Called Kerry in my other life
I live at UTC + 13.00
Nima2018
« Reply #2 on: February 16, 2019, 12:33:27 AM »
Hi kdub
Thanks for your reply .
At LINE of getting first point (my_pt1) I see this error :
      Argument missing
kdub_nz
  • SuperMod
« Reply #3 on: February 16, 2019, 01:16:15 AM »
Do you think it may be because you have a comma with no prior value in the parameter list??
« Last Edit: February 16, 2019, 01:20:24 AM by kdub »
Nima2018
« Reply #4 on: February 16, 2019, 02:01:14 AM »
Yes, visual studio show red sign under comma.
I check my code on another machine and results was same as previous .
gile
  • Marseille, France
« Reply #5 on: February 16, 2019, 02:17:38 AM »
Unlike VB(A), C# does not allow a blank for an optional argument before a comma. You have to specify a Type.Missing argument.
Code - C#: [Select]
  1. my_pt1 = AcadApp.ActiveDocument.Utility.GetPoint(Type.Missing, "Please click on the first point :");
My only advice shoud be: while using C#/.NET keep as far as you can away from the COM interop...
« Last Edit: February 16, 2019, 02:34:35 AM by gile »
Nima2018
« Reply #6 on: February 16, 2019, 10:28:52 AM »
Yes, I thank you for your helps, and I will definitely act on your advice, dear gile .
