Author Topic: automatic REnumbering sheet in SSM  (Read 4639 times)
jtm2020hyo
« on: February 12, 2019, 11:23:06 PM »
it is there a routine (or anything) to automatic REnumbering sheets?
Jeff H
Re: automatic REnumbering sheet in SSM
« Reply #1 on: February 13, 2019, 09:00:36 AM »
I got something that spits out all the sheet set properties to an excel file, then I edit it as needed and use that to update the sheet set.
jtm2020hyo
« Reply #2 on: February 13, 2019, 01:53:49 PM »
can you share the tool name or code?
Jeff H
« Reply #3 on: February 13, 2019, 02:41:40 PM »
We are slammed at work, but I can find some time this week to dig it out. I might just paste code instead of loading up a zip, since it references ACSMCOMPONENTSXXLib and requires a different build for each year.
« Reply #4 on: February 13, 2019, 03:30:27 PM »
jmtm226, have a look at this forum thread. There are some tools in there, including Jeff H's findings, that should help.
http://www.theswamp.org/index.php?topic=46497.0
Jeff H
« Reply #5 on: February 14, 2019, 06:10:28 PM »
Before I spend time digging it,
  • do you understand and know how to use it to create your own project?
  • do you have Excel installed on your computer?
If someone else would like the to use it and know how to create their own project to use it just reply also and will dig it out.
jtm2020hyo
« Reply #7 on: February 16, 2019, 05:48:27 PM »
If someone else would like to use it and know how to create their own project to use it just reply also and will dig it out.
I know a bit how to create a VB.NET for this guide:
http://aucache.autodesk.com/au2016/sessionsFiles/22323/13686/handout_22323_SD22323-L%20Hands%20On%20Introduction%20to%20C%23%20Add-Ins%20for%20AutoCAD.pdf
but I do not use Excel, but I use LibreOffice Calc.
jtm2020hyo
« Reply #8 on: February 17, 2019, 03:24:11 PM »
I was reading the whole post. But I did not find something related to renumbering sheets in SSM. but I find one code to convert since .dst to .xml.
can you share an example with their explaining?
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #9 on: February 17, 2019, 05:56:01 PM »
jntm226,
Do you have any experience programming ?
I've noticed that MP ( Michael ) has offered a solution here : http://www.theswamp.org/index.php?topic=52362.msg593049#msg593049
Have you tried to edit the .XML file as suggested ?
I'm wondering if you have difficulty understanding the process.
I see that you have threads running in several areas of this site so I can imagine that a solution is important to you.
This particular problem requires time and targeted knowledge to resolve. I don't think you can expect people to take time out of their busy days to provide a personalised solution that required such specialised knowledge.
Called Kerry in my other life
I live at UTC + 13.00
