Author Topic: Running shortcut with autolisp  (Read 3741 times)
@_Bilal
  • Mosquito
« on: February 12, 2019, 07:19:31 PM »
Hi Guys,
Someone can help me to run from AutoLISP using Shell object the following shortcut
Target: C:\Users\Myfolder\updater.exe /checknow
thank you in advance
Re: Running shortcut with autolisp
« Reply #1 on: February 12, 2019, 07:57:38 PM »
A bit long in the tooth and I don't have time to test if it still works but the shortcut portion of this code worked way back when ... link.
« Reply #2 on: February 13, 2019, 08:23:20 AM »
This?
(command "_.shell" "C:\\Users\\Myfolder\\updater.exe /checknow")
« Reply #3 on: February 13, 2019, 08:41:54 AM »
The original question is a little confusing--and I think Lee has already answered it but if the question is: "how to create a shortcut with lisp", I had this in one of my old files. You will have to update the information to suit your needs.
  1. ( (lambda ( / sh shorcutlnk)
  2.     ;; how to create a shortcut with Visual Lisp
  3.     (setq sh
  4.           (vla-getInterfaceObject
  5.             (vlax-get-acad-object) "WScript.Shell")
  6.           shortcutlnk (vlax-invoke-method sh 'CreateShortcut (strcat "C:\\Documents and Settings\\" (getvar 'LOGINNAME) "\\Desktop\\AutoCAD MEP (US Imprerial).lnk")))
  7.     (vlax-put-property shortcutlnk 'TargetPath "\\Program Files\\ABS2008\\acad.exe\" /ld \"C:\\Program Files\\ABS2008\\AecBase.dbx\" /p \"AutoCAD (Mech)")
  8.     (vlax-put-property shortcutlnk 'IconLocation "%SystemRoot%\\Installer\\{5783F2D7-6006-0409-0002-0060B0CE6BBA}\\abs2008.ico, 0")
  9.     (vlax-put-property shortcutlnk 'WindowStyle 1)
  10.     (vlax-put-property shortcutlnk 'Hotkey "")
  11.     (vlax-put-property shortcutlnk 'Description "Launch AutoCAD MEP 2008 with Company Profile")
  12.     (vlax-invoke-method shortcutlnk 'Save)
  13.     (vlax-release-object shortcutlnk)
  14.     )
  15.  )
@_Bilal
  • Mosquito
« Reply #4 on: February 13, 2019, 09:56:52 AM »
Tanks for All
The target file "updater.exe" resides in
"C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe"
While the shortcut "soft_Updater.lnk" resides in
"C:\\Users\\username\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\softwareFolder\\soft_Updater.lnk"
When i ran the updater.exe file from the target directly
(command "_.shell" "C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe")
failed result:-------the cmd screen run then close immediatetly
(command "_.shell" "C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe /checknow")
success result:-------But two screens run at the same time one is cmd screen and the other is for updater.exe
when trying to run the shortcut "soft_Updater.lnk"
(command "_.shell" "C:\\Users\\username\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\softwareFolder\\soft_Updater.lnk")
When using Lee Mac function
(LM:Open "C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe")
return T:-------but nothing happens.
(LM:Open "C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe /checknow")
Return nil
(LM:Open "C:\\Users\\username\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\soffold\\soft_Updater.lnk")
Return T:------------the updater.exe run alone without the cmd screen. Which is perfect
What i am looking for is to run (LM:open "C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe /checknow")
is it possible?
VovKa
  • Ukraine
« Reply #5 on: February 13, 2019, 10:31:43 AM »
no Shell
(startapp "C:\\Users\\username\\AppData\\Roaming\\softwareFolder\\updater.exe" "/checknow")
« Reply #6 on: February 13, 2019, 12:27:58 PM »
Absolute VovKa. :)
@_Bilal
  • Mosquito
« Reply #7 on: February 13, 2019, 03:05:09 PM »
Great,
success result:-------------updater.exe run in a proper manner
Thanks, Vovka, and Thanks every budy
