Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Convert VLA-OBJECT IVector
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Convert VLA-OBJECT IVector (Read 1709 times)
FELIX
Bull Frog
on:
February 01, 2019, 02:17:15 PM »
How to convert "VLA-OBJECT IVector"? Read your content.
Logged
OK.
Gemini
Mosquito
WWW
Re: Convert VLA-OBJECT IVector
Reply #1 on:
February 20, 2020, 07:08:24 AM »
Check here:
http://www.theswamp.org/index.php?topic=38072.msg514709#msg514709
Logged
Rod
Newt
Reply #2 on:
February 23, 2020, 06:13:05 PM »
Hi Felix,
did you have any luck with this?
From memory the iVector contained a list of numerators and a list denominators that corresponded with degrees minutes and seconds
I copied this directly from the code I already posted
https://www.theswamp.org/index.php?topic=38072.msg592382#msg592382
Code - Auto/Visual Lisp:
[Select]
defun
getgpsvalue
vectorObj
Numlist Denomlist i numerator denominator dms dd
setq
Numlist
getitemfromcollection vectorobj
"Numerator"
setq
Denomlist
"Denominator"
setq
i
0
repeat
3
if
and
setq
numerator
nth
i Numlist
setq
denominator
nth
i Denomlist
not
zerop
denominator
;_ end of and
setq
dms
cons
float
numerator
denominator
dms
setq
dms
cons
0
dms
;_ end of if
setq
i
1+
i
;_ end of repeat
setq
dms
reverse
dms
setq
dd
getdecimaldegrees dms
;_ end of defun
Cheers, Rod.
Logged
"All models are wrong, some models are useful" - George Box
Rod
Newt
Reply #3 on:
February 23, 2020, 06:14:59 PM »
This may provide more info
https://docs.microsoft.com/en-us/previous-versions/windows/desktop/wiaaut/-wiaaut-rational
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
