If you want to see what the drawing looks like on the screen, you can use zoom C command.
Enter zoom at the command line and C at the center of the screen, which is the center of the drawing you want to see.
Then it shows you to enter the ratio or height, then measure the height of the screen drawing area with a ruler, that is, how many millimeters the height of the black (or white) window is, just enter Enter. My screen is 269 mm.
In this case, if the ratio is 1 mm = 1 graphic unit, if it is not 1 = 1, but 1 = 100 Tianzheng, the told value here will multiply this ratio, 269 should be input 26900.
Then use the translation command to see the picture, not the wheel. What you see is the actual size of the drawings, and print out the same size.
Try it, is it simple?
