Author Topic: Frustrated with Dynamo learning  (Read 13196 times)
Hangman
« on: January 23, 2019, 05:14:30 PM »
K, so I've tried getting some info from others regarding learning some dynamo to no avail.
Lemme try this route then;
I want to create a simple routine so when I am in a project, I can run the script to check if there are any linked revit models &/or any CAD files.  If there are any linked files, to remove them from the open project.
Does this sound easy enough?  I hope so.
Question, Where do I start?   How can I know what nodes to start this simple routine?
In VBscript, Java, C#, C++, etc, etc, there are always a reference manual one can peruse to learn what command or node does what function.  With Dynamo there seems to be NOTHING.  So frustrating.
Hangman  8)
lamarn
Re: Frustrated with Dynamo learning
« Reply #1 on: October 04, 2019, 05:15:59 AM »
Matt__W
  • I like my water diluted.
« Reply #3 on: October 08, 2019, 07:09:50 PM »
Linked Models
https://dynamonodes.com/2016/04/14/get-all-revit-links-as-element-list/
Linked/Imported DWGs
https://forum.dynamobim.com/t/how-do-i-use-dynamo-to-locate-and-delete-imported-dwgs/13249/7
Autodesk Expert Elite
SlickRicky
  • Mosquito
« Reply #4 on: December 26, 2020, 01:19:59 PM »
whoa!!!! now that's sic...  :smitten:
