Author Topic: Update attribute in sideDatabase (AutoCAD 2019)  (Read 2066 times)
djee
« on: January 21, 2019, 09:57:47 AM »
This code does not work anymore on AutoCAD 2019. I'm targeting the Framework 4.7. The managed .NET Reference guide specified that the function
Database.ReadDwgFile(string, FileShare, [MarshalAs(UnmanagedType.U1)] bool, string) Method is obsolete & will be remove in future release. When debugging, It does not iterate through the object ID's in the BlockTableRecord? Could the function have been replace? I'm looking into the Graphic system changes... But any input would be nice...
Thanks.
Public Shared Sub UpdateAttributesInSideDatabase(ByVal FilePath As String, blockName As String, attbName As String, attbValue As String)
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim currentDb As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Using targetDb As New Database(False, True)
            Try
                targetDb.ReadDwgFile(FilePath, System.IO.FileShare.ReadWrite, True, "")
                Using tr As Transaction = targetDb.TransactionManager.StartTransaction()
                    Dim layoutDict As DBDictionary = tr.GetObject(targetDb.LayoutDictionaryId, OpenMode.ForRead)
                    For Each dicEnt As DBDictionaryEntry In layoutDict
                        Dim lay As Layout = DirectCast(dicEnt.Value.GetObject(OpenMode.ForRead), Layout)
                        ''do your stuffs in every layout
                        If lay.LayoutName <> "Model" Then
                            Dim btr As BlockTableRecord = tr.GetObject(lay.BlockTableRecordId, OpenMode.ForRead)
                            For Each id As ObjectId In btr
                                If id.ObjectClass.DxfName = "INSERT" Then
                                    Dim br As BlockReference = DirectCast(tr.GetObject(id, OpenMode.ForRead), BlockReference)
                                    ' ... to see whether it's a block with
                                    ' the name we're after
                                    If br.Name.ToUpper() = blockName.ToUpper() Then
                                        For Each arId As ObjectId In br.AttributeCollection
                                            Dim ar As AttributeReference = DirectCast(tr.GetObject(arId, OpenMode.ForRead), AttributeReference)
                                            ' ... to see whether it has
                                            ' the tag we're after
                                            If ar.Tag.ToUpper() = attbName.ToUpper() Then
                                                ' If so, update the value
                                                ' and increment the counter
                                                ar.UpgradeOpen()
                                                ar.TextString = attbValue
                                                'realign attributes after editing their values
                                                'ar.AdjustAlignment(targetDb)
                                                'ar.DowngradeOpen()
                                            End If
                                        Next
                                    End If
                                End If
                            Next
                        End If
                    Next
                    'end of code from template insert
                    tr.Commit()
                End Using
                targetDb.SaveAs(FilePath, DwgVersion.Current)
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                ed.WriteMessage(vbLf & "Error while running > " + ex.Message)
            End Try
        End Using
    End Sub
Re: Update attribute in sideDatabase (AutoCAD 2019)
« Reply #1 on: January 21, 2019, 10:25:10 AM »
Change this:
to this:
targetDb.ReadDwgFile(FilePath, FileOpenMode.OpenForReadAndWriteNoShare, True, "")
