Author Topic: Help to Import Excel Data to AutoCAD  (Read 1709 times)
Yamishon
« on: January 15, 2019, 01:37:26 AM »
I have simple excel file to be imported to AutoCAD..
I have searched lot but did not get proper one.
I want a lisp, which will ask
   1. select a excel file  or specified in lisp
   2. Range or specified in lisp
   3. Should ask for text height in AutoCAD
   4. make table
   5. Command to update this table
I don't want to use Data link or table from autocad as I have to deal with many table everytime so need routine for it.
Kindly help me out...
Yamishon
PKENEWELL
« Last Edit: January 15, 2019, 10:06:26 AM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
Gemini
  • Mosquito
Re: Help to Import Excel Data to AutoCAD
« Reply #2 on: January 15, 2019, 03:26:47 PM »
Hi Yamishon,
I have something to open a excel file and write the information in AutoCAD. Not in a table but in block.
It's a start, if you want.
