Inserting geographic location information to a drawing file makes points within the drawing correspond to geographic locations on the surface of the Earth.Geographic location information in a drawing file is built around an entity known as the geographic marker. The geographic marker points to a reference point in model space that corresponds to a location on the surface of the earth of known latitude and longitude. The program also captures the direction of the north at this location. Based on this information the program can derive the geographic coordinates of all other points in the drawing file.Typically a geographic location is defined by its coordinates (for example, latitude, longitude, and elevation) and the coordinate system (for example, WGS 84) used to define the coordinates. Moreover, the coordinates of a location can differ from one GIS coordinate system to another. Hence, when you specify the geographic location of the geographic marker, the system also captures the details of the GIS coordinate system.Typically CAD drawings are unitless and are drawn at 1:1 scale. You are free to decide the linear unit a drawing unit represents. GIS systems, on the other hand, allow the coordinate system to decide the linear units. In order to map CAD coordinates to GIS coordinates, the system needs to interpret CAD drawing units in terms of linear units. The system uses the setting stored in the INSUNITS system variable as the default linear measurement of a drawing unit. However, when you insert geographic location information, you have the option of specifying a different linear measurement (for a drawing unit).You can remove geographic location information from a drawing file using the GEOREMOVE command. The geographic marker and GIS coordinate system are removed from the drawing file. However, position markers continue to remain in the drawing file.
It worked, but i don't understand why it set a Geo marker since I didn't gave it this command. This isn't the first time either.
(if (/= (getvar 'geomarkervisibility) 0)(progn(setvar 'geomarkervisibility 0)(princ "\nGeomarkerVisibility turned off. GEOMARKERVISIBILITY")))
You could add this to your acaddoc.lsp:Code: [Select](if (/= (getvar 'geomarkervisibility) 0)(progn(setvar 'geomarkervisibility 0)(princ "\nGeomarkerVisibility turned off. GEOMARKERVISIBILITY")))
Quote from: tombu on January 29, 2019, 08:49:43 AMYou could add this to your acaddoc.lsp:Code: [Select](if (/= (getvar 'geomarkervisibility) 0)(progn(setvar 'geomarkervisibility 0)(princ "\nGeomarkerVisibility turned off. GEOMARKERVISIBILITY")))Why bother checking it? Why not just set it?
