Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help with sorting lists and using "cons" to add multiple lists.
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Help with sorting lists and using "cons" to add multiple lists. (Read 8228 times)
Needs a day job
Re: Help with sorting lists and using "cons" to add multiple lists.
Reply #15 on:
January 18, 2019, 12:52:19 PM »
Glad to help
. Really you don't need all the pages if you use the vl-remove-if-not method. Here's a quick example:
Code - Auto/Visual Lisp:
[Select]
setq
i
0
;;(setq keep (mapcar 'itoa '(1 4 8 9 12 15)))
repeat
50
setq
pages
cons
setq
i
1+
i
pages
vl
remove
if
not
lambda
x
12
x
25
reverse
pages
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
