Author Topic: Recording Subdirectories  (Read 3068 times)
whdjr
« on: June 08, 2005, 09:30:19 AM »
I have this code that returns all the directories and subdirectories of the supplied path.
;;;usage (list_folders "d:\test" T)
;;;path --> is the starting path
;;;sub --> is either T or nil for recording subdirectories
(defun list_folders (path sub)
  (defun get_folders (folder / f)
    (mapcar '(lambda (x)
      (setq f (strcat folder "\\" x))
      (if sub
(cons f (apply 'append (get_folders f)))
   (cddr (vl-directory-files folder nil -1))
  (cons path (apply 'append (get_folders path)))
What I would like is to see if someone could help me modify it so that it will only concantenate the folder names after the original path.
Example:
This is my folder structure:
If I set my original path as 'd:\test' I want it to return ('test a' 'test a\test a1' 'test a\test a2' 'test b' 'test b\test b1' 'test b\test b2') without the orinigal path included.
Does that make any sense?
« Reply #1 on: June 08, 2005, 09:39:06 AM »
First gather (in a list) all paths as fully qualified paths, e.g. ("d:\\test\\test a" "d:\\test\\test a\\ test a1" ...).
Then, using mapcar, apply a function to the list that strips of the first 'n' characters of every item, said length corresponding to the original path plus 1.
/idea
whdjr
« Reply #2 on: June 08, 2005, 09:48:38 AM »
Yeah that's the easy way. :D
What I want to do is compare a list of folder structures that will have a different starting path, so I didn't want to have to add the path and then remove the path.  If that's the easiest way then I guess I could do that, I just thought the other way would be quicker. :?
Jürg Menzi
  • Oberegg, Switzerland
« Reply #3 on: June 08, 2005, 10:42:45 AM »
Hi Will
Maybe this one can help:
; == Function MeGetFolders
; Scans from current folder (recursive) for folders (and files).
; Arguments [Type]:
;   Fol = Root folder [STR]
;   Pat = File name pattern
;         - Not False: eg. *.*, *.dwg [STR]
;         - False:     Folders only [BOOLEAN]
;   Rec = Recursive flag [BOOLEAN]
;         - True:  scan folders recursive
;         - False: scan first folder level
; Return [Type]:
;   > If pattern argument False:
;     '("Pth1" "Pth2"...) [LIST]
;   > If pattern argument not False:
;     '(("Pth1" '("Fil1" "Fil2"...)) ("Pth2" '(...))...) [LIST]
; Notes:
;   - If no files found in a folder, the file list returns a '("").
;   - Deep folder structure slow down the function.
(defun MeGetFolders (Fol Pat Rec / FolLst TmpFol)
 (setq TmpFol (if (wcmatch Fol "*\\") (substr Fol 1 (1- (strlen Fol))) Fol)
       FolLst (cons TmpFol (apply 'append (MeGetFoldersRec TmpFol Rec)))
 (if Pat
  (mapcar
  '(lambda (l)
    (cons l (cond ((vl-directory-files l Pat 1)) ('(""))))
   ) FolLst
  FolLst
; == Function MeGetFoldersRec
; Recursive function for MeGetFolders.
; Arguments [Type]:
;   Fol = Folder [STR]
; Return [Type]:
;   > Folder list '((Pth1) (Pth2)) [LIST]
; Notes:
;   Return value contain nil atoms.
(defun MeGetFoldersRec (Fol Rec / TmpFol)
 (mapcar
 '(lambda (l)
   (if (not (wcmatch l "`.*"))
    (cons
     (setq TmpFol (strcat Fol "\\" l))
     (if Rec (apply 'append (MeGetFoldersRec TmpFol Rec)))
  ) (vl-directory-files Fol nil -1)
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
whdjr
« Reply #4 on: June 08, 2005, 01:22:20 PM »
This is what I came up with following MP's advice even though I think it is too much processing.  If anyone has any more thoughts please share.  For now I will use this and continue.
(defun get_folders (path) (cddr (vl-directory-files path nil -1)))
(defun str_cat (path name) (strcat path "\\" name))
(defun get_subs (folder / f)
    (setq f (str_cat folder x))
    (cons f (apply 'append (get_subs f)))
 (get_folders folder)
(setq tfolder "C:\\ADT 2005 CD Image"); <--Insert your folder name here
(mapcar '(lambda (x) (substr x (1+ (strlen tfolder))))
(apply 'append (get_subs tfolder))
Thanks MP.
« Reply #5 on: June 08, 2005, 01:35:56 PM »
My pleasure Will.
First thing I'd do once I proved an algorythm works is attempt to remove any unnecessary processing, esp. from iterative coding, for example --
(setq pointer (1+ (strlen tfolder)))
(mapcar
   '(lambda (x) (substr x pointer))
Also, consider that your core functions should perform the bulk of this work for you, that is, the mapcar bit above should be transparent to the caller.
/IMO
whdjr
« Reply #6 on: June 08, 2005, 01:43:24 PM »
That was a last minute add after I realized 'vl-string-left-trim removed too much of the string.  I didn't test it fully before posting. :?
I know, I know, that is a bad practice.  I won't let it happen again Mr.Puckett. :)
« Reply #7 on: June 08, 2005, 01:52:57 PM »
Wasn't trying to sound finger wavin' Will, just trying to help in whatever small ways I can.
whdjr
« Reply #8 on: June 08, 2005, 02:02:50 PM »
Yeah I know, I was just havin a little laugh. :lol:
« Reply #9 on: June 08, 2005, 02:10:56 PM »
Jürg, Hey thats perty cool! I like that.
Jürg Menzi
« Reply #10 on: June 09, 2005, 04:32:38 AM »
Quote from: Se7en
Thx for the flowers :)
