Author Topic: Change Multileader Defined Height  (Read 3866 times)
Dave M
« on: January 08, 2019, 03:36:15 PM »
I'm revising a dwg that I didn't create.  There are alot of mleaders, and the box for the mtext seems to be the same for all of them.  Many are one line of text, or hard wrapped multi-line, but the box is much larger than needed.  This creates a problem when masking because the mask it too large.  I have tried double-clicking the ruler to shrink the box, but it reverts back to the original height when I exit the command.
I don't see a "defined height" setting in the properties window like with mtext.
If anyone has a good solution to fix this, I would love to know what it is.
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Re: Change Multileader Defined Height
« Reply #1 on: January 08, 2019, 04:20:58 PM »
Have you tried selecting them all and changing the text width to 0?
Windows 10 x64 - AutoCAD /C3D 2020
Dave M
« Reply #2 on: January 08, 2019, 05:59:45 PM »
Yes, and the width will hold, but not the height of the box.  Probably should have said I'm using 2018 in my OP
Bryco
« Reply #3 on: January 14, 2019, 08:10:57 PM »
Does quick select mleaders then change the landing gap in the properties window help?
Dave M
« Reply #4 on: January 16, 2019, 11:52:08 AM »
I can quick select the multileaders and adjust their landing gap distance, but that doesn't do anything for the height of the text box portion.  If you select an mtext object and look at the properties, one of them will be defined height.  But if you select an mleader object and look at its properties defined height is not an option.
The only thing that seems to be working is to select a lower grip and snap it to a top grip. Sigh
cadtag
« Reply #5 on: January 16, 2019, 03:49:19 PM »
Thats' been irritating me for a while now.  I'm glad you found a fix, even if it is one at a time.  thanks!
« Reply #6 on: January 16, 2019, 04:54:44 PM »
After digging into this a bit more this seems to work ( AutoCAD 2019 ). I would test it out though. I've 'entmodded' mleaders in the past and get some funky results.
  1. (defun c:foo (/ s)
  2.   ;; RJP 2019-01-16
  3.   ;; Reset mleader textbox height
  4.   (if (setq s (ssget ":L" '((0 . "multileader"))))
  5.     (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
  6.       (entmod (subst '(44 . 0.0) (assoc 44 (entget e)) (entget e)))
  7.     )
  8.   )
  9.   (princ)
  10. )
« Last Edit: January 16, 2019, 04:59:03 PM by ronjonp »
Dave M
« Reply #7 on: January 17, 2019, 02:44:17 PM »
  7.     )
  8.   )
  9.   (princ)
  10. )
Thanks ronjop!
So far it seems to working well.  The only thing I can think that would make it better is if it could shrink to the extents of the text.  I don't code so I appreciate any help I can get.  I suspect the files I'm working on were converted from Microstation or another platform.
Thanks, again!
« Reply #8 on: January 17, 2019, 04:13:26 PM »
Maybe post a sample drawing. The grips wrap to text on my drawing.
kdub
  • Mesozoic keyThumper
  • SuperMod
« Reply #9 on: January 17, 2019, 05:13:14 PM »
Ron,
when the dust settles ... is there a story behind that leader text quote ??
Regards,
called Kerry in my other life
#ridesober
« Reply #10 on: January 18, 2019, 09:01:07 AM »
Ron,
Regards,
No story .. sometimes the hamster falls off the wheel and unexpected results occur :).
netelaana
  • Mosquito
« Reply #11 on: June 01, 2020, 11:24:42 AM »
  7.     )
  8.   )
  9.   (princ)
  10. )
you have no idea how many hours of tedium you just saved. Thanks!
« Reply #12 on: June 01, 2020, 12:32:27 PM »
  7.     )
  8.   )
  9.   (princ)
  10. )
Glad to help!  :-)
au785
  • Mosquito
« Reply #13 on: May 25, 2021, 10:13:04 AM »
  7.     )
  8.   )
  9.   (princ)
  10. )
Yeah, I'm that kind of CAD user who will get unbearably bothered by things that don't really matter that much such as mleader grips that are lower than the actual text box.
You just saved me so much time with your gorgeous routine. Thank you endlessly.
« Reply #14 on: May 25, 2021, 10:22:32 AM »
  7.     )
  8.   )
  9.   (princ)
  10. )
Glad you can use it :)
