Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Create a layer filter if Attribute tag value = X
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Create a layer filter if Attribute tag value = X (Read 1619 times)
jlogan02
Bull Frog
on:
January 07, 2019, 03:29:49 PM »
I want to use this portion of code...
Code - Auto/Visual Lisp:
[Select]
defun
FDN_LayGrpFltr
setq
osm
getvar
'osmode
setvar
'osmode
0
setvar
'cmdecho
0
defun
lm:getattributevalue
blk tag
val enx
while
and
null
val
"ATTRIB"
cdr
assoc
0
setq
enx
entget
setq
blk
entnext
blk
if
strcase
tag
strcase
cdr
assoc
2
enx
setq
val
cdr
assoc
1
enx
setq
ss
ssget
"x"
0
"INSERT"
2
"TBLK_ATT_CTL"
66
1
setq
attvalue
ssname
ss
0
"TITLELINE4"
cond
wcmatch
strcase
attvalue
"FOUNDATION PLAN"
with something like this
[Select]
command
"._layer"
"Filter"
"New"
"Group"
"S-FDN-*"
"S_FDN_Layers"
command
"._layer"
"Make"
"S_FDN"
"color"
"Cyan"
"S_FDN"
setvar
'osmode osm
setvar
'cmdecho
1
princ
FDN_LayGrpFltr
To create a layer filter group if the TitleLine4 reads "x" (Foundation Plan in this example).
The alternative to using the Attribute tag value would be to use the paper space tab name 'Foundation Plan".
I'm getting the "bad argument type: lselsetp nil. I assume because I'm missing an ssnamex
[Select]
if
setq
FDNLay
ssget
"X"
8
"S-FDN"
foreach
x
mapcar
cadr
ssnamex
FDNLay
Or something to this effect.
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Dlanor
Bull Frog
Re: Create a layer filter if Attribute tag value = X
Reply #1 on:
January 08, 2019, 03:11:19 AM »
The error means there is nothing in the selection set, i.e. there are no objects on layer "S-FDN"
Logged
Dlanor
http://www.theswamp.org/donate.html
jlogan02
Bull Frog
Reply #2 on:
January 08, 2019, 12:00:58 PM »
Gaaaaahhh!!! I knew that. Simple things.
I kept saying it's not find what it's looking for.
Thank D.
Logged
J. Logan
ACAD 2018
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
