Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
ConvexHull----bug?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ConvexHull----bug? (Read 1651 times)
well20152016
Newt
ConvexHull----bug?
on:
January 04, 2019, 06:08:09 AM »
Code - Auto/Visual Lisp:
[Select]
defun
c:test
setq
lst
LM:ConvexHull
mapcar
cdr
vl
remove
if
not
lambda
x
car
x
10
entget
car
entsel
entmakex
append
list
cons
0
"LWPOLYLINE"
cons
100
"AcDbEntity"
cons
100
"AcDbPolyline"
cons
90
length
lst
cons
70
1
cons
62
1
mapcar
function
lambda
p
cons
10
p
lst
;; Convex Hull - Lee Mac
;; Implements the Graham Scan Algorithm to return the Convex Hull of a list of points.
defun
LM:ConvexHull
lst
ch p0
cond
length
lst
4
lst
setq
p0
car
lst
foreach
p1
cdr
lst
if
or
cadr
p1
cadr
p0
and
equal
cadr
p1
cadr
p0
1e
8
car
p1
car
p0
setq
p0 p1
setq
lst
vl-sort
lst
function
lambda
a b
c d
if
equal
setq
c
angle
p0 a
setq
d
angle
p0 b
1e
8
distance
p0 a
distance
p0 b
c d
setq
ch
list
caddr
lst
cadr
lst
car
lst
foreach
pt
cdddr
lst
setq
ch
cons
pt ch
while
and
caddr
ch
LM:Clockwise
p
caddr
ch
cadr
ch
pt
setq
ch
cons
pt
cddr
ch
ch
;; Clockwise-p - Lee Mac
;; Returns T if p1,p2,p3 are clockwise oriented or collinear
defun
LM:Clockwise
p
p1 p2 p3
car
p2
car
p1
cadr
p3
cadr
p1
cadr
p2
cadr
p1
car
p3
car
p1
1e
8
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Re: ConvexHull----bug?
Reply #1 on:
January 04, 2019, 06:20:26 AM »
Refer to this post :
http://www.theswamp.org/index.php?topic=53116.msg578882#msg578882
Also for ConvexHull - pts on Hull refer to my latest codes posted for TSP started by Evgeniy Elpanov
HTH., M.R.
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
well20152016
Newt
Reply #2 on:
January 04, 2019, 07:00:05 AM »
thank!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
ConvexHull----bug?
