Author Topic: Activation issue rant  (Read 7356 times)
« on: December 17, 2018, 07:06:57 PM »
So, I've had to re-install Windows and I cannot get A2k7 to register. I saved the registration information from previously and I made sure I entered all the information exactly the same, but when I try to activate, I get a 204 error. I tried getting an activation key from Autodesk and the request code is 8 characters less than the registration form will accept. I am getting the dreaded 204 error …
I know I should upgrade, but I can't justify the expense and not to mention its a subscription ... and I only design 4 or 5 houses a year.
It just pisses me off.
Carry on with your regularly scheduled programming.
Re: Activation issue rant
« Reply #1 on: December 18, 2018, 07:46:53 AM »
« Reply #2 on: December 18, 2018, 10:06:59 AM »
Pain in da....
However, it might be that you would need to write ZEROS to your entire HD
And then reinstall everything...
dgorsman
« Reply #3 on: December 18, 2018, 10:42:31 AM »
Odds are, the Windows re-install invalidated the previous activation code.  Something that old, I wouldn't bother with auto/online activation and go straight to the reseller for help getting manual codes.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Gergeobusges
  • Mosquito
« Reply #4 on: December 21, 2018, 12:21:45 AM »
The topic you set up is very interesting. I have studied and read more continuously.
kdub
  • SuperMod
« Reply #5 on: December 21, 2018, 03:18:05 AM »
George. Do you actually have anything constructive to add to the conversation ??
called Kerry in my other life
#ridesober
« Reply #6 on: December 21, 2018, 08:50:05 AM »
Maybe he’s just curious.
Engineering Technologist • Programmer Analyst • CAD Specialist
Multi-Discipline • Design • Drafting • Document Control • Automation.
cadanalyst@gmail.comwww.linkedin.com/in/cadanalyst
kdub
  • SuperMod
« Reply #7 on: December 21, 2018, 01:05:20 PM »
Yes, perhaps I should be more poetic.
#ridesober
« Reply #8 on: January 04, 2019, 11:57:09 AM »
A couple of calls and I find out that Autodesk has stopped issuing activations for software older than AutoCAD 2014.
Seriously?
I have a PERPETUAL LICENSE!!! That means FOREVER. Autodesk apparently believes they can arbitrarily deny a user access to licensed software they obtained lawfully.
I am trying to do this legitimately, but they are trying my patience!
« Reply #9 on: January 04, 2019, 12:15:21 PM »
Sorry Keith, Autodesk seems bent on alienating their customers while BricsCAD seems bent on earning customer and developer loyalty. Cue Kenny Rogers.
« Reply #10 on: January 04, 2019, 12:25:58 PM »
I tried to get a developer license a couple of times and was denied because I'm not going to sell the software ( internal use ). Thought that was kinda strange since they would get 6 more customers if we took their route.
Totally agree about Adesk.
Windows 10 x64 - AutoCAD /C3D 2020
dgorsman
« Reply #11 on: January 07, 2019, 11:41:01 AM »
"Perpetual" shouldn't be considered literally, it doesn't mean "forever-forever".  At some point they do have to cut things off.  Otherwise they end up wasting time with people trying to install AutoCAD 2019 on 32-bit Win XP or some such.  Or they have to include so much spaghetti code in the program to support all those possibilities.
Might also consider they are using a third-party licensing tool.  There may be restrictions on their end we just aren't seeing.
try {GreatPower;}
      {MasterBasics;}
cadtag
« Reply #12 on: January 08, 2019, 07:48:54 AM »
"Perpetual" is literal.  Adesk is legally obligated to provide authentication codes until the heat death of the universe.  That doesn't mean that they have to provide support for Acad 2005 under whatever OS platform is available in 2525, but they do have to provide the correct authorization codes for any legal purchaser who did not upgrade.  That's true until Adesk folds it tent and creeps quietly into the night of bankruptcy.
Adobe got around that by releasing universal codes for their last non-rental version,
rkmcswain
« Reply #13 on: January 08, 2019, 08:08:48 AM »
THIS ^^^^^
@Keith - who told you that Autodesk has "stopped issuing activations"?
That is wrong.
« Reply #14 on: March 12, 2019, 11:42:19 PM »
THIS ^^^^^
That is wrong.
I don't recall now, its been a while. It was through the Autodesk website.
In order to get back to work, I restored an old drive and was able to use the software … until this weekend. Windows pushed out an update and AutoCAD no longer works … again!!
I've obtained an email address for their technical support and I sent a request. So far no response, but I didn't expect an answer right away.
Regardless, I only have 5 days before AutoCAD stops working completely and I am right in the middle of 3 projects and I was informed I will be receiving two more in the next week.
