Author Topic: How to divide by increment between paramaters  (Read 1780 times)
estanima
« on: December 17, 2018, 02:15:26 PM »
Could use a hand with this.  I need to place circles on polyline segments at 5-ft increments between the vertices (parameters). Having a difficult time.  Additionally, the circles can't be within 5-ft of any parameter.  Here's a very bad start (basically junk) that doesn't do what I want. I keep fumbling around so thought I'd ask here for help (sorted is the number of parameters in the polyline):
for (int i = 0; i < sorted.Count - 1; i++) //minus 1 so it doesn't fail on last parameter
                            Point3d parampoint = temppoly.GetPointAtParameter(i);
                            Point3d afterpoint = temppoly.GetPointAtParameter(i + 1);
                            double distance = parampoint.DistanceTo(afterpoint);
                            if (distance > 5.1 && (distance + 5.1) < temppoly.GetDistanceAtParameter(i + 1))
                                Circle cr = new Circle(temppoly.GetPointAtDist(temppoly.GetDistanceAtParameter(i) + 5), Vector3d.ZAxis, 1.0);
                                acBlkTblRec.AppendEntity(cr);
                                MyTrans.AddNewlyCreatedDBObject(cr, true);
Thanks everyone, appreciate your help.
« Last Edit: December 17, 2018, 02:19:19 PM by quadman »
Re: How to divide by increment between paramaters
« Reply #1 on: December 17, 2018, 03:13:20 PM »
Something like this should do it.
Code - C#: [Select]
  1.                     for (int i = 0; i < poly.EndParam; i++)
  2.                     {
  3.                         var len = 5.0;
  4.                         var startlen = poly.GetDistanceAtParameter(i);
  5.                         var endlen = poly.GetDistanceAtParameter(i + 1);
  6.                         while ((startlen += len) < (endlen - 5.0))
  7.                         {
  8.                             var pt = poly.GetPointAtDist(startlen);
  9.                             Circle cr = new Circle(pt, Vector3d.ZAxis, 1.0);
  10.                             acBlkTblRec.AppendEntity(cr);
  11.                             MyTrans.AddNewlyCreatedDBObject(cr, true);
  12.                         }
  13.                    }
  14.
estanima
« Reply #2 on: December 17, 2018, 04:29:46 PM »
Flawless, thank you.  Seeing your code made it look so easy :(   :uglystupid2:
Code - C#: [Select]
  2.                     {
  3.                         var len = 5.0;
  7.                         {
  12.                         }
  13.                    }
  14.
