Author Topic: Can't purge *A blocks  (Read 3346 times)
jbuzbee
« on: December 17, 2018, 09:00:13 AM »
I have a bunch of blocks in a drawing that are named *A000. Does anyone know what type of blocks these are?
Thanks,
j buzbee
James Buzbee
Windows 8
GDF
Re: Can't purge *A blocks
« Reply #1 on: December 17, 2018, 09:45:00 AM »
anonymus blocks
« Reply #2 on: December 17, 2018, 09:53:52 AM »
Usually anonymous blocks are *U#. Are you sure these blocks aren't referenced somewhere? Post the drawing if you can.
« Reply #3 on: December 17, 2018, 09:58:32 AM »
Thanks,
j buzbee
open some in block editor
dgorsman
« Reply #4 on: December 17, 2018, 10:09:37 AM »
Open the block definition with the VLIDE.  You can step through the entities in a text format, which can be handy if the block is empty or has hard-to-see content.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
« Reply #5 on: December 17, 2018, 03:00:22 PM »
Annotation scaling objects, e.g.
dictionaries (root)
-> (dictionary) "ACAD_SCALELIST"
   -> Pointers to anonymous blocks
or ...
Annotation enabled object (e.g. dimenstion)
-> Extension dictionary
   -> Dictionary
      -> (AcDbDictionary) Dictionary
         -> (AcDbContextDataManager) Dictionary
            -> (ACDB_ANNOTATIONSCALES) Dictionary
               -> (AcDbAlignedDimensionObjectContextData) Anonymous block
                  -> (AcDbScale)
                     -> Data for the scale, description & values
jbuzbee
« Reply #6 on: December 18, 2018, 10:32:43 AM »
Ah that makes sense
Thanks MP
James Buzbee
Windows 8
« Reply #7 on: December 18, 2018, 02:03:18 PM »
My pleasure James; cheers.
