I have a snipet of code I am trying to write into a routine and I would prefer to "suppress" some of the prompts on the screen.
(defun frm (pnt)
(getpoint "from" pnt)
(setvar "osmode" 512)
(setq pnt1 (getpoint "\nFirst Point: "))
(setvar "osmode" 128)
(prompt "\nSecond Point: ")
(setq pnt2 (frm pnt1))
The intent is to have the user select a point nearest on a line then point 2 is perpendicular to a parallel line from point 1 (is that clear?). I would prefer the "from" command was not displayed at the prompt after "Second Point:" Is this possible? Other suggestions?
Thanks,
Dan
