Author Topic: Set a default and ask the user for input  (Read 4952 times)
jlogan02
« on: December 06, 2018, 07:22:01 PM »
I'm trying to make this work but can't seem to get it done.
I want to ask the user for a ltscale for the zigzag line to be drawn on [.25/.5]
with a default .5
I get that the code sets a default but it doesn't deal with a real number and
that I need to use getreal. But I can't make it work.
  1. (if (null global:int)
  2.     (setq global:int 1)
  3. )
  4. (if (setq tmp (getint (strcat "\nEnter a positive non-zero integer <" (itoa global:int) ">: ")))
  5.     (setq global:int tmp)
  6. )
  1. (defun c:ZigZag (/ clt clts lts clayr a)
  2.   (setq oldosmode (getvar 'osmode))
  3.   (setq clt (getvar 'celtype))
  4.   (setq clts (getvar 'celtscale))
  5.   (setq lts (getvar 'ltscale))
  6.   (setq clayr (getvar 'clayer))
  7.   (setvar 'osmode 1)
  8.   (setq a "zigzag")
  9.
  10. (getreal "\Enter LTSCALE [.25/.5] :")
  11.
  12. (if (= (tblsearch "ltype" a) nil)
  13.     (command "-linetype" "l" a "acad.lin" "")
  14.   )
  15.
  16.   (command "._layer" "make" "CLOUD" "Color" "RED" "CLOUD" "")
  17.   (command "-linetype" "_s" a "")
  18.   (command "pline")
  19.
  20.   (while (> (getvar 'cmdactive) 0)
  21.   (command pause))
  22.
  23.   (setvar 'celtype clt)
  24.   (setvar 'celtscale clts)
  25.   (setvar 'clayer clayr)
  26.   (setvar 'ltscale lts)
  27.   (setvar 'osmode oldosmode)
  28.   (princ)
  29. )
J. Logan
ACAD 2018
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Grrr1337
Re: Set a default and ask the user for input
« Reply #1 on: December 06, 2018, 07:45:32 PM »
Like this ? :
  1. (setvar 'LTSCALE
  2.   (read
  3.     (progn
  4.       (initget "0.25 0.5")
  5.       (cond ((getkword "\nEnter LTSCALE [0.25/0.5] <0.5>: "))("0.5"))
  6.     )
  7.   )
  8. )
(apply ''((a b c)(a b c))
vevo.bg
« Reply #2 on: December 07, 2018, 07:48:45 AM »
Another Option:
  1. ;;  CAB 12.26.2009
  2. ;;  example Get number within a Numeric Range
  3. ;;    Arguments
  4. ;;  If nil, Ignore MinNum or MaxNum or DefNum
  5. ;;  msg and ErrMsg may be nil as well
  6. (defun GetNumInRange(MinNum MaxNum DefNum msg ErrMsg / num)
  7.   (or msg (setq msg "\nEnter number: "))
  8.   (or ErrMsg (setq ErrMsg "\nEntry is out of range. Try Again."))
  9.   (while
  10.     (cond
  11.       ((null (setq num (getdist msg)))
  12.        (if DefNum
  13.          (null (setq num DefNum))
  14.          (princ ErrMsg)
  15.        )
  16.       )
  17.       ((and MinNum (< num MinNum))
  18.        (princ ErrMsg))
  19.       ((and MaxNum (> num MaxNum))
  20.        (princ ErrMsg))
  21.     )
  22.   )
  23.   num
  24. )
  25.
  26. (defun c:test()
  27.   (print
  28.   (GetNumInRange 10 50 39 "\nEnter number [10 =< Num >= 50]."
  29.                      "\nError - entry is out of range. Try Again.")
  30.     )
  31.   (princ)
  32.
  33. )[\code]
  34.
jlogan02
« Reply #3 on: December 07, 2018, 12:01:21 PM »
Great work on both parts Grrr1337 and CAB. Thanks. I have questions.
Grrr1337. Please just confirm for me. I'd like to search and destroy for myself.
As it stands now this only allows for 0.25 and 0.5. I know some users like to forego enter the "0" and just use .25 or .5.
Is there a way to insure either input is accepted.
  1. (setvar 'LTSCALE
  2.   (read
  3.     (progn
  6.     )
  7.   )
  8. )
I placed the GetNumInRange Defun code right after my routines defun and placed
  1.   (GetNumInRange 0.25 1.0 39 "\nEnter number [0.25 =< Num >= 1]."
  2.                      "\nError - entry is out of range. Try Again.")
  3.     )
Just below my if statement.
  1. ...(if (= (tblsearch "ltype" a) nil)
  2.     (command "-linetype" "l" a "acad.lin" "")
  3.   )
  4. (GetNumInRange 0.25 1.0 39 "\nEnter number [0.25 =< Num >= 1]."
  5.                      "\nError - entry is out of range. Try Again.")
  6.     )
  7.
  8.   (command "._layer" "make" "CLOUD" "Color" "RED" "CLOUD" "")
  9.   (command "-linetype" "_s" a "")
  10.   (command "pline")
  11.
  12.   (while (> (getvar 'cmdactive) 0)
  13.   (command pause))
  14.
  15.   (setvar 'celtype clt)
  16.   (setvar 'celtscale clts)
  17.   (setvar 'clayer clayr)
  18.   (setvar 'ltscale lts)
  19.   (setvar 'osmode oldosmode)
  20.   (princ)
  21. )
  22.
It prints the message to the command line and I can enter  a number. However, the ZigZag line result is always Ltscale of 1.0 no matter what I enter.
J. Logan
ACAD 2018
« Reply #4 on: December 07, 2018, 12:22:24 PM »
If you set DYNMODE to 1, Grrr's code should popup the options on the screen.
« Reply #5 on: December 07, 2018, 12:28:31 PM »
Here's another option:
  1. (defun c:test ( / scl )
  2.     (while
  3.         (progn
  4.             (initget 6)
  5.             (not (member (setq scl (cond ((getreal "\nEnter LTSCALE [.25/.5] <.5>: ")) (0.5))) '(0.25 0.5)))
  6.         )
  7.         (princ "\nPlease choose between 0.25 & 0.5.")
  8.     )
  9.     (setvar 'ltscale scl)
  10. )
This will accept user input of 0.25/.25/0.5/.5.
jlogan02
« Reply #6 on: December 07, 2018, 01:01:08 PM »
I beat you to the punch on that one RonJonp but thanks for the message
Grrr1337...Works like a charm now.
Lee...
What is the
  1. (not (member...
doing? I like having that option to enter either way. It's what would be expected from an AutoCAD command.
J. Logan
Acad 2018
Edit: Don't answer that last question Lee. I never realized I could just click on any of the blue text and be taken to a definition page for that word. Life just got easier, me thinks. I know...what was I thinking?
« Last Edit: December 07, 2018, 01:08:30 PM by jlogan02 »
J. Logan
ACAD 2018
« Reply #7 on: December 07, 2018, 01:16:24 PM »
You have John Kaul (Se7en) to thank for that cool feature of this site  :wink:
jlogan02
« Reply #8 on: December 07, 2018, 01:39:57 PM »
Well then, Thank you John Kaul (Se7en) for that handy feature. Well played sir!
J. Logan
ACAD 2018
J. Logan
ACAD 2018
« Reply #9 on: December 07, 2018, 02:04:22 PM »
Glad you got it sorted .. FWIW here's a little constructive criticism. Happy coding! :)
  1. (defun c:zigzag (/ *error* a oldosmode)
  2.   ;; Error handler to reset osmode if you hit a snag
  3.   (defun *error* (msg)
  4.     (and oldosmode (setvar 'osmode oldosmode))
  5.     (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **")))
  6.     (princ)
  7.   )
  8.   (setq oldosmode (getvar 'osmode))
  9.   ;; No need to gather all these variable since you're not changing them below
  10. ;;;  (setq clt (getvar 'celtype))
  11. ;;;  (setq clts (getvar 'celtscale))
  12. ;;;  (setq lts (getvar 'ltscale))
  13. ;;;  (setq clayr (getvar 'clayer))
  14.   (setvar 'osmode 1)
  15.   ;; Use one of the sugestions here
  16.   (initget 6)
  17.   (getreal "\Enter LTSCALE [.25/.5] :")
  18.   ;; this could be
  19. ;;;  (if (= (tblsearch "ltype" a) nil)
  20. ;;;    (command "-linetype" "l" a "acad.lin" "")
  21. ;;;  )
  22.   ;; this
  23.   (or (tblsearch "ltype" (setq a "zigzag")) (command "-linetype" "l" a "acad.lin" ""))
  24.   (command "._layer" "make" "CLOUD" "Color" "RED" "CLOUD" "")
  25.   (command "-linetype" "_s" a "")
  26.   (command "pline")
  27.   (while (> (getvar 'cmdactive) 0) (command pause))
  28.   ;; No need to set all these variable since they never changed
  29. ;;;  (setvar 'celtype clt)
  30. ;;;  (setvar 'celtscale clts)
  31. ;;;  (setvar 'clayer clayr)
  32. ;;;  (setvar 'ltscale lts)
  33.   (setvar 'osmode oldosmode)
  34.   (princ)
  35. )
jlogan02
« Reply #10 on: December 07, 2018, 02:48:03 PM »
Thanks for that RonJonp. I don't mind at all when someone points things out to me.
Have a good weekend.
J. Logan
ACAD 2018
J. Logan
ACAD 2018
jlogan02
« Reply #11 on: December 07, 2018, 04:52:57 PM »
Turns out I have to revisit this. I forgot about adjusting for drawings with different Dimscale settings
  1.     (progn
  2.       (initget 6)
  3.         (not (member (setq scl (cond ((getreal "\nSet LTSCALE [.25 Text/.5 Lines] <.5>: ")) (0.5))) '(0.25 0.5)))
  4.     )
  5.      (Alert "\nYou Must Choose 0.25 or 0.5")
  6.   )
  7.   (setvar 'ltscale scl)
Am I correct in saying the above is setting the ltscale based on the result the user picks?
  1. (setq scl (cond...
  2. (setvar 'ltscale scl)
If so, it seems to me I need to add the use of the dimscale variable in the (cond statement. Not sure though.
J. Logan
ACAD 2018
J. Logan
ACAD 2018
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #12 on: December 07, 2018, 06:54:37 PM »
How about something like
  1. (setvar 'ltscale (* scl (getvar "DIMSCALE")))
Because it's a scalar value your users will understsand that either option will be multiplied by Dimscale
... or add a note to the prompt to that effect.
Called Kerry in my other life
I live at UTC + 13.00
jlogan02
« Reply #13 on: December 08, 2018, 01:45:42 PM »
Thanks kdub.
So this is how I tried it before asking this forum.
Same thing but alot more typing???
  1. (setq dim (getvar 'dimscale)
  2. (setvar 'ltscale (* scl dim))
Well that and it didn't seem to work the first time. Just tried it again as a test and it worked.
Maybe it was a simple as me not changing the dimscale to something other than (1) when I tested the first time.
J. Logan
ACAD 2018
jlogan02
« Reply #14 on: December 08, 2018, 02:27:27 PM »
Something isn't right with this code.
It does everything I want, but I'm finding that the linetype scale doesn't seem to be
correct. When I check the properties of a zigzag line I've drawn, it shows the ltscale as 1.00. When I clearly chose .25 or .5.
It will not let me physically change the ltscale property in the properties dialog unless I use the calculator. When I do, it changes the zigzag linetype scale and size to what I assume is the correct scale.
Am I truly drawing the zigzag line at my chosen ltscale?
  1. (defun c:ZigZag (/ *error* a oldosmode)
  6.         (princ (strcat "\n** Error: " msg " **"))
  7.     )
  8.     (princ)
  9.   )
  10.   (setq cosmode (getvar 'osmode))
  11.   (setq clt (getvar 'celtype))
  12.   (setq clayr (getvar 'clayer))
  13.   (setvar 'osmode 1)
  14.   (setq a "zigzag")
  15.
  16.   (while
  17.     (progn
  18.       (initget 6)
  19.         (not (member (setq scl (cond ((getreal "\nSet LTSCALE [.25 Text/.5 Lines] <.5>: ")) (0.5))) '(0.25 0.5)))
  20.     )
  21.      (Alert "\nYou Must Choose 0.25 or 0.5")
  22.   )
  23.
  24.   (setvar 'ltscale (* scl (getvar 'dimscale)))
  25.
  26.   (if (= (tblsearch "ltype" a) nil)
  27.     (command "-linetype" "l" a "acad.lin" "")
  28.   )
  29.
  30.   (command "._layer" "make" "CLOUD" "Color" "RED" "CLOUD" "")
  31.   (command "-linetype" "_s" a "")
  32.   (command "pline")
  33.
  34.   (while (> (getvar 'cmdactive) 0)
  35.     (command pause)
  36.   )
  37.
  38.   (setvar 'osmode cosmode)
  39.   (setvar 'celtype clt)
  40.   (setvar 'clayer clayr)
  41.
  42.   (princ)
  43. )
« Last Edit: December 10, 2018, 10:41:09 AM by jlogan02 »
J. Logan
ACAD 2018
