Author Topic: AutoCad 2018 Commands Not Ending  (Read 2751 times)
fish
« on: December 04, 2018, 04:38:18 PM »
Hello all, recently switched to AutoCad 2018 from 2007 and it seems that AutoCad never really finishes a command, I'm constantly hitting the escape key to end the command.  It also seems very slow in switching layouts.  I cache my model and layout tabs and that helps somewhat.  Overall AutoCad 2018 just seems slower, is there something that I don't have set properly?  Thanks!
Re: AutoCad 2018 Commands Not Ending
« Reply #1 on: December 04, 2018, 04:39:30 PM »
AutoCAD gets slower with every release.  :tickedoff:
« Reply #2 on: December 04, 2018, 07:31:05 PM »
Paging BricsCAD ...
dgorsman
« Reply #3 on: December 05, 2018, 10:02:31 AM »
Paging BricsCAD ...
I can't help but notice I'm doing more with each release (without much loss of speed).  But maybe that's just me.   :whistling:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
57gmc
« Reply #4 on: December 05, 2018, 10:45:53 AM »
Dan: Was that the release of AutoCAD or BricsCAD?
Fish: Some commands have changed since 2007. e.g. the COPY command. It continues to operate for multiple copies. Its like the M option is the default. You have to hit {Enter} to finish the command.
rkmcswain
« Reply #5 on: December 07, 2018, 10:52:14 AM »
Quote from: fish
On the same PC? 2018 requires a lot more horsepower than 2007 did.
Quote from: fish
I had a user with the same problem yesterday. Is your layer palette open? If so, and you close it, does the time to switch layouts improve?
For this user of mine, it's like night and day. With the layer palette open, it takes about 5 seconds to switch layouts.
With the layer palette closed, it's virtually instantaneously.
Having said that, the layer palette being open should not be that much of a burden on this. My user only had about 200 layers, not 8000.
You could literally see it painting each line of the palette each time.
I ensured my user had the recommended display adapter driver also.
